I am a beginner to ROS2, I am trying to learn how to build our own packages in ROS2. If anyone knows any website which explains the procedure please share the link. Looking forward for your help.
Regards,
Chandrashekhar
Regards,
Chandrashekhar
HI, Thanks for your interest in ROS2. However please take a moment to read through our Support Guidelines for the appropriate way to reply to topics. Support - ROS Wiki
Posting here in a projects announcement channel, and your reply to a jobs post are off topic. Questions should be asked on ROS Answers our Q&A forum.
Also please consider taking a little bit more time to fill out your question. The better and more specific your question the better an answer you will get. Your question is generic enough that the first link on a search for ROS2 is about as good an answer as you can get: GitHub - ros2/ros2: The Robot Operating System, is a meta operating system for robots. with links to Tutorials, contributing guide and developer guide.
I’ve moved this to uncategorized and will close this thread after this post.
