What problem does RCM solve? RCM was initially designed to manage installation scripts of various ROS1/ROS2 source codes and startup scripts through the interface. After continuous expansion and improvement, it has now become a bash-based shell script management tool under Ubuntu/Linux.
RCM is a bash-based shell script management tool. After installation, the shell script that meets the definition can be converted into a system command with RCM as the command, script path, and script name as the subcommand. At the same time, it provides a powerful Tab auto-completion function to realize quick search of scripts.
Three modes are provided for running scripts:
Auto-completion mode: rcm (supported by 2.x series and above)
Search mode: rcm -s (supported above 1.x)
Interface mode: rcm-gui or click the RCM (commands) icon (supported by 1.x series or above)
new features
Change the running mode and change the search mode to automatic completion mode, similar to the ros2 one-line command style
Unified the style, the main command is rcm, the desktop moderator command is rcm-gui
Unified script style, making scripts more independent and easier to expand
Add more ros2 related scripts
Added convenient mechanisms for creating directories and scripts
Add ailibot robot simulation development kit
Add ailibot2 robot simulation development kit
Add ailibot model development package
demo
- Query script, use tab method to automatically complete subcommands
rcm <tab><tab> <tab><tab>
- install ros2
rcm ros2 install_ros2_now
- install ros1
rcm ros1 install_ros1_noetic
- Update rosdep for mainland China
rcm common update_rosdep_tsinghua
- install turtlebot3
rcm ros1_tb3 install_tb3_noetic_apt
- install turtlebot4
rcm ros2_tb4 install_tb4_galactic_apt
- Create a directory
rcm system create --dir poker --dirdesc "poker script dirctory"
- Create script
rcm system create --dir poker --script build --scriptdesc "to build rcm"
Easy to Installation:
curl -k https://www.ncnynl.com/rcm.sh | bash -
About the code :
