Hi Kim, hi all,
“Swarms” is a somewhat controversial term, from what I heard. We should define it in the first place I think. Usually authors remain large in their definition :
“a swarm of UAVs is a set of aerial robots that work together for a specific goal.” [1]
"A swarm is generally defined as a group of behaving entities that together coordinate to produce a significant or desired result." [2]
But some other authors argue that “swarm” implies decentralized control, as it is the case in nature.
In my lab, we are working on decentralized flocking for autonomous, communicating multi-UAV systems, so I’ll talk mostly about that
- What are the pain points you are facing?
- We would like to simulate both the robotics component (physics of the UAVs, command/control using PX4 Autopilot, obstacle sensing / avoidance, etc.) and the network component (quality of UAV-to-UAV and UAV-to-Ground channels, multiple data flows cohabitation with different QoS, etc.). But we lack an “off the shelf” co-simulator for robotics and network integration (that supports DDS). I am developing such a simulator as part of my Ph.D., can talk about that if that’s interesting.
- Positioning in a GPS-denied environment remain a pain-point. We are using decentralized UWB distance measurements atm. Other approaches exist.
- What is the limiting factor of communication?
I’ll stick with Bekmezci’s analysis of what is different in FANETs opposed to other MANETs [3] :
- Mobility degree
- Frequent topology change
- Must support peer-to-peer and converge cast traffic
- Longer distances between nodes
- Different requirements for different sensors
In general these points have several answers but people work mainly on improving the antenna systems and the routing algorithms implemented in the swarm.
- Which are the important values to monitor for swarm management?
On the top of my head :
- Number of connected clusters
- Fully disconnected UAVs (i.e. lost UAVs)
- Average speed / maximum speed of the swarm
But actually I’ve never really operated a swarm of UAVs in real life, so that’s all theoretical
Note that many of these questions arise for our specific use-case of autonomous mission deployment, everything is different if you allow yourself to have a central base station connected to all the robots, or if you allow GPS, or fly heavier UAVs, etc.
See you tomorrow !
[1] X. Chen, J. Tang, and S. Lao, “Review of Unmanned Aerial Vehicle Swarm Communication Architectures and Routing Protocols,” Applied Sciences, vol. 10, no. 10, p. 3661, May 2020, doi: 10.3390/app10103661.
[2] M. Campion, P. Ranganathan, and S. Faruque, “UAV swarm communication and control architectures: a review,” J. Unmanned Veh. Sys., vol. 7, no. 2, pp. 93–106, Jun. 2019, doi: 10.1139/juvs-2018-0009.
[3] İ. Bekmezci, O. K. Sahingoz, and Ş. Temel, “Flying Ad-Hoc Networks (FANETs): A survey,” Ad Hoc Networks, vol. 11, no. 3, pp. 1254–1270, May 2013, doi: 10.1016/j.adhoc.2012.12.004.
