The following are the notes from the Space ROS Pojrect committee Meeting. Notes were taken by Sean Kolk, with contributions from those in attendence.
- Attendees
- Dave Coleman, PickNik Robotics
- Sean Kolk, PickNik Robotics
- Brian Kempa, NASA Ames
- Evan Laske, NASA JSC
- Stephen Hart, TRACLabs
- Austin Probe, Emergent Space Technologies
- Eddie Tunstel, Motiv Space Systems
- Matt Hansen, ROS 2 community contributor
- Ivan Perez, KBR / NASA Ames Research Center
- Scott Mende, Maxar Space Robotics
- Ian Ferguson, Lockheed Martin
- Preliminaries
- [Dave] Need a note taker to post this on Discourse
- Old business
- [Sean] Reminder of 2023 SMC-IT/SCC Workshop on Space Robotics Software next week
- https://smcit-scc.space will be July 18th, 19th and 20th
- The Space Robotics Workshop will be July 19th
- The Open Source for Space workshop will be July 20th
- [Matt] Update on the Space ROS Github repo, contributors, and activity
- Technical contributors are collaborating in a PickNik-sponsored shared Slack channel & on GitHub
- We are working with Ivan Perez on aligning Space ROS development on GitHub with NPR 7150 requirements.
- We are expecting to start having regular, frequent technical meetings (biweekly?) soon
- The group is still working on release schedules
- [Ivan] Update on NPR 7150 requirements
- GitHub - nasa/ogma: Generator of runtime monitors for flight and robotics applications.
- They are updating the current space ROS Image
- Which will always build on top of Space ROS
- The goal of this is to make NASA reqs syce more seamlessly
- Part of the documentation process requires all changes to link to an issue (for any commit)
- This allows auditors to trace back ‘why’ any change has been made.
- There are still questions about how this will sync with core ROS.
- Tool support & documentation under development, and a paper should be available in 1 month.
- [Michael J] Updates on the website and docs
- New business
- Possible Topics:
- State of the Union of the codebase / prior work done
- Brian: There’s a request for an FAQ for technical decisions
- Look for anything with the question of ‘what was michael J’s thoughts on this’
- Take this topic to the new Space ROS technical working group
- Developing and sharing high level requirements
- Use Austin’s team’s prior work and update the reqs?
- There was no requirements document previously
- Definition of requirements: you have a particular use case in mind and it has requirements that then drives technical work
- Another definition: requirements for ppl to get involved in Space ROS
- Another definition: NASA’s flight software requirements
- Request: A Space ROS glossary (Brian
- Use box.com account to share powerpoint deck with Space ROS folks (Ivan will create the Box account)
- Developing a long term (public) road map
- Explain how Blue Origin is no long the driver of Space ROS
- Austin Probe will take point on this
- Lower level technical road map also needs to be developed (this is the application focused thrusts)
- Matt: (how do we get Space ROS on space applications) Can we set a goal to have a simple Space ROS POC doing something (robot arm, astrobee, ground robot) in a mission by end of 2024? Then we target missions with a POC and solicit funding, etc.
- Mission statement:
- Ivan: To streamline the process of getting ROS into space missions..
- To streamline the process of qualifying and leveraging ROS for space missions.
- Decrease the time and effort it takes to build and deploy robotics applications in space through open source standards.
- Austin: focus on accelerating capabilities (do not focus on ROS)
- Provide safe access to existing robotics ecosystems and communities
- Accelerating robotics capabilities in space through the qualification of existing open source ecosystems
- Objectives:
- Accelerating
- Reduce time for Qualification
- Reusability
- Modularity
- what does ROS not provide, but is not a individual project req
- Don’t duplicate V&V and tooling
- Platform
- Non-mission specific
- Draft: Accelerate robotics capabilities in space by creating tools for qualification (validation?) of open source ecosystems. Decrease the time and effort to develop robotics applications through reuse and modularity.
- Problem Statement? Every mission has unique requirements, and every qualification process is bespoke to those missions. This yields less re-use of existing software / capabilities. Can we make this process less bespoke, and leverage others’ experience.
- Long term File Sharing
- Nasa will have trouble storing any files to the public
- A separate group (OSRF?)
- Ivan is coordinating
- Has made a Box
- A NewACO/Space Act Agreement that is NASA + OSRF + Partners, to formalize or to create an umbrella organization.
- Blue Origin had the original ACO - it was not written in a way that would be an open source project
- A new version could be made that would focus on the open source aspect
- Evan: This group could/should look at setting up an ACO with STMD
- Background: ACO’s are a way for NASA to work publicly with companies, but wouldn’t necessarily be funding in itself
- Ref: “Long Term” - Always keep a “prospective mission” as part of this to help move the things forward (list of Candidate missions and plans for engagement)
- Clarify difference between Space ROS and ROS 2. Still seems to be unclear to some folks. Perhaps can cover this as part of State of the Union.
- Possible Topics:
- Topics for next meeting:
- Review software requirements document starting with Austin’s version
