Hi, I am trying to set up an ESP32 based bot running MicroROS connected to a my ROS host running on Docker. My base project has the device side subscribing to the /cmd_vel topic, where I am trying to publish messages from the tuttlesim telop_key executable on my ROS host and I am expecting to see the call back in my code being activated thru debug messaging on my device.
I see my device register with the agent on boot and I see the device spinning waiting for a message but I am not seeing the node in the node graph.
I was expecting to see a Node in the node graph representing my connected device thru the Agent.
When I issue commands via the teleop key executable, I am not seeing the call back being activated.
I am looking for insight on how to debug this ??
The project is located here GitHub - gentijo/RosBots.archive
The code as it is should run on any ESP32, I haven’t added any specific code to control the device itself yet.
The files of importance on the device are;
Main code to init the ESP32 and MicroROS
https://github.com/gentijo/MaqueenBattleBots/blob/main/microros_ws/bots/maqueen-esp32/main/main.c
Registers the subscription and prints debug on call back.
https://github.com/gentijo/MaqueenBattleBots/blob/main/microros_ws/bots/maqueen-esp32/main/exc_sub_velocity.c
I am running unmodified Agent code.
Debug output from my Device
Output from the Agent
Thank you
John
