Posted by @cwrx777:
I’m trying to understand how skip phase works and encountered error in the fleet adapter after skip phase request is submitted.
Logs
After task request is submitted:
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Handling [dispatch_task_request] request_id: [direct_cd0cf889-f801-4f55-9b07-e044951d73d5]
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Requesting new schedule update because update timed out
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] [rmf_traffic_ros2::MirrorManager::request_update] Requesting changes for query ID [1] since version [14]
[rmf_task_dispatcher-13] [rmf_dispatcher_node][INFO] Add Task [compose.dispatch-0] to a bidding queue
[rmf_task_dispatcher-13] [rmf_dispatcher_node][INFO] - Start new bidding task: compose.dispatch-0
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] [Bidder] Received Bidding notice for task_id [compose.dispatch-0]
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Planning for [2] robot(s) and [1] request(s)
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Submitted BidProposal to accommodate task [compose.dispatch-0] by robot [tinyRobot1] with new cost [35.974384]
[rmf_task_dispatcher-13] [rmf_dispatcher_node][INFO] Determined winning Fleet Adapter: [tinyRobot], from 1 responses
[rmf_task_dispatcher-13] [rmf_dispatcher_node][INFO] Dispatcher Bidding Result: task [compose.dispatch-0] is awarded to fleet adapter [tinyRobot], with expected robot [tinyRobot1].
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Bid for task_id [compose.dispatch-0] awarded to fleet [tinyRobot]. Processing request...
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Beginning next task [compose.dispatch-0] for robot [tinyRobot/tinyRobot1]
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Beginning new task [compose.dispatch-0] for [tinyRobot/tinyRobot1]. Remaining queue size: 0
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] TaskAssignments updated for robots in fleet [tinyRobot] to accommodate task_id [compose.dispatch-0]
After task skip phase request is submitted:
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Selecting a new go_to_place location from [1] choices for robot [tinyRobot/tinyRobot1]
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Got distance from [24] as 21.280834
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Planning for [tinyRobot/tinyRobot1] to [coe] from one of these locations:
[fleet_adapter-15] -- L1 <10.4331 -5.5751> [tinyRobot1_charger] | on waypoint | orientation 76.1012
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Handling [skip_phase_request] request_id: [compose.dispatch-0]
[fleet_adapter-15] [tinyRobot_fleet_adapter][INFO] Executing go_to_place [coe] for robot [tinyRobot/tinyRobot1]
[fleet_adapter-15] [tinyRobot_command_handle][INFO] Commanding [tinyRobot1] to navigate to [10.08614619 -6.97943654 2.54466843] on map [L1]: cmd_id 2
[fleet_adapter-15] terminate called after throwing an instance of 'nlohmann::detail::type_error'
[fleet_adapter-15] what(): [json.exception.type_error.305] cannot use operator[] with a numeric argument with object
Steps to replicate:
Edit tinyRobot_config.yaml in office demo:
actions: ["custom_action"] -
Launch office simulation (after rebuilding
rmf_demosworkspace).ros2 launch rmf_demos_gz_classic office.launch.xml -
Submit a task request with the following content:
{ "type": "dispatch_task_request", "request": { "unix_millis_earliest_start_time": 0, "category": "compose", "description": { "detail": "Text to describe the task.", "category": "this_can_be_anything", "phases": [ { "activity": { "category": "perform_action", "description": { "category": "custom_action", "description": {}, "unix_millis_duration_estimate": 60000 } } }, { "activity": { "category": "go_to_place", "description": { "waypoint": "coe" } } } ] } } }response
{ "state": { "booking": { "id": "compose.dispatch-0", "unix_millis_earliest_start_time": 0 }, "category": "compose", "detail": { "category": "this_can_be_anything", "detail": "Text to describe the task.", "phases": [ { "activity": { "category": "perform_action", "description": { "category": "custom_action", "description": {}, "unix_millis_duration_estimate": 60000 } } }, { "activity": { "category": "go_to_place", "description": { "waypoint": "coe" } } } ] }, "dispatch": { "errors": [], "status": "queued" }, "status": "queued", "unix_millis_start_time": 0 }, "success": true } -
Submit Skip Phase Request:
skip phase request
{ "type": "skip_phase_request", "task_id": "compose.dispatch-0", "phase_id": 1, "labels": [ "test skip phase" ] }response
{ "success": true, "token": "0" }
