ROS PMC Business
- Accelerated Memory Transport Working Group Charter
- A vote will be sent out immediately for approval (requires quorum, otherwise async).
- @ahcorde to chair the working group, @skye.galaxy to serve as backup contributor.
Regular Business
Buildfarm update
- PTAL Buildfarm Issues Triage Sheet
Issues
Priorities
- RQT Issues in Rolling
- Don’t worry about fixing the rqt/rolling/noble combo, as shiboken6 isn’t available (but is available on resolute).
- rosbag2_transport test_recorder_event_notifier expected size mismatch in Jazzy/Kilted/Rolling nightly connext
- Mjcarroll to ping rti people about it
- TestBroadcasterAndListener.test_static_broadcaster_and_listener failing in CI repeated jobs
Waffle note-taker
- January 8 + January 15 - @wjwwood
Rosdistro assignments
Rosdistro is a weekly assignment to monitor incoming issues and pull requests in GitHub - ros/rosdistro: This repo maintains a lists of repositories for each ROS distribution. Two people per week are assigned to be the rosdistro maintainers.
Release Management
- Audrow (Humble)
- No updates.
- Yadu (Rolling)
- Marco (Jazzy)
- No updates.
- Scott (Kilted)
Working Group Updates
- Client Library Working Group
- ROSGraph Working Group (unofficial)
- Took December off, first meeting January 6th
- Discussing declarative node interfaces
- Launch documentation as a bg task
Agenda
- [AMT WG] Native Buffers
- Update on ROS native buffers
- CY: Specifically would like review with an eye towards backwards compatibility and flexibility such that any 3p can implement their own backend.
- CY: It has a wider scope (rmw and rosidl) so deep reviews are appreciated.
- @mjcarroll to coordinate a special session for a deep dive.
- [mjcarroll] Thoughts on Pixi as a co-official way of installing ROS on Linux
- Discussion: Debate on the stability of “rolling” dependency managers vs. the Red Hat/Debian model.
- [mjcarroll] request for input on Tomoya’s logging feature: [FR] select the logger implementation without rebuilding · Issue #1178 · ros2/rcl · GitHub
- [claraberendsen] Update on Windows 11 transition
- Kimberly is working on bringing up MSVC 2022 and get rid of warning related to cyclonedds: Windows 11 support · Issue #832 · ros2/ci · GitHub.
- We can confirm WIn 11 binaries work on Windows 10 as of today.
- [claraberendsen] Resolute 26.04 stand-up
- Almost finished with the Infrastructure setup
- Need to deploy repository configuration to repo.ros2.org and we should be able to test.
- I will open an issue tracker to track what breaks.
- [cottsay] RHEL 10 standup
- Everything from last week, except:
- I was able to use xwfb-run to unblock the RViz tests. Didn’t try the visual testing framework, though
- I believe that Fast-DDS issues were resolved (thanks Miguel!)
- Early build: https://ci.ros2.org/job/test_ci_linux-rhel/64/
