Hello, hope you’re doing well!
In the task board description md file, it says that the nic cards have orientation limits of -10 to +10 degrees. Can you please clarify if this orientation is along which axis?
Best,
Best,
The rotation is along the yaw axus, ie axis normal to the plane of the task board.
thanks Yadunund for responding. So to confirm, the board will have certain yaw (say +30 degrees). if the card has +10 degrees, then in world, the card will be at 40 degrees. Is that right? So the card orientation (±10degrees) is not the board orientation.
