I have a Turtlebot2 / Kobuki base but no charger for it. I’ve searched online and can’t seem to find any for sale anywhere. If anyone has a link to where I might purchase one, I’d appreciate it.
Thanks.
Thanks.
Hi Matt,
I looked at the spec sheet and you need an Input: 100-240V AC, 50/60Hz, 1.5A max; Output: 19V DC, 3.16A power supply.
Here’s an example on Amazon: Amazon.com: 19V 3.15A 60W Charger AC Adapter for Cpa09-004a Np365e5c Np510r5 Np200a5b Np270e4e Np300e5a Np300e5e Np305e5a R440 R480 R530 R540 R580 CPA09-004 NP270E4E NP270E5E Laptops Power Supply Cord : Electronics
As for the barrel connector, I measured mine at 5mm. The one linked above is 5.5mm, which I assume would also probably work with a little tough love.
S
Thanks @smac, I’ll give that one a try.
My charger broke and I am looking to replace it ASAP.
From the datasheet, I was only able to find the voltage/frequency/current specifications of the charger: Anatomy — kobuki 2.0 documentation
From what I can tell the end is a male barrel connector with positive polarity and measures 5mm in diameter. Is this correct?
