I noticed that on some images i can see mutliple mounts per rail. Buw how do you define that there is no example in the sample scenarios? Something like this? But that would not work
in the docs/task_board_description.md, it says there could be at most 5 SC ports distributed over two rails. But when I was looking at aic_description/urdf/task_board.urdf.xacro, and I only see two SC ports (instead of 5)
So for qualification phase, would we only have at most 1 SC port on each rail? Thanks!!
