I can run an ignition server with ign gazebo -s, and then connect a UI to it (on the same host) with ign gazebo -g.
It feels like it should be possible to run ign gazebo -g on a different computer and connect to ign gazebo -s over the network, as e.g. the web UI defaults to ws://localhost:9002.
How can I have ign gazebo -s start the websocket server?
How can I have ign gazebo -g connect over a websocket to the websocket server from 1?
Both computers have to have the same value of environment variable IGN_PARTITION (and also IGN_TRANSPORT_TOPIC_STATISTICS set to either 0 or 1 on both machines). And they have to be connected over LAN. Then you don’t need to do anything about WebSockets and they connect. If you need this to work over WAN, then the WebSocket server and web client would probably be better (or you can connect the two computers with a VPN).
I see… and how can I run the websocket server in CLI (I don’t see anything related to websocket in ign gazebo -h)?
Also, is it possible to connect the client over websocket (with ign gazebo -g), or is websocket only working with the web UI (i.e. not the “desktop” UI started with ign gazebo -g)?
Hi! I’m running the websocket and a simulation (example of shapes.sdf) but when trying to access from https://app.gazebosim.org/visualization it is only available at localhost:9002, is there a way to make it available to local network?
