I’m encountering an issue where my solution works correctly in local testing, but fails during submission/evaluation, and I’d like to clarify a couple of points.
- Docker image size
My current submission image is quite large (~56GB).
Are there any explicit or implicit limits on image size for submission?
Could a large image cause failures during upload, deployment, or evaluation?
- Multiple environments / processes
In my setup:
The ROS 2 lifecycle node (
aic_model) runs in one environment -
The model inference runs in a separate environment (launched via subprocess)
This setup works reliably in local tests, and all lifecycle and action behaviors appear correct.
I would like to confirm:
Is this multi-environment / multi-process setup allowed?
Are there any restrictions on spawning subprocesses or using multiple Conda/Micromamba environments inside the container?
Any guidance would be greatly appreciated, as I’m trying to understand why a locally working solution fails after submission.
Thanks!
