Hi everyone, our team name is starvla.
Our model runs correctly in the local environment, but the submission has failed several times after uploading.
Our setup uses micromamba to launch a separate inference environment/process for the VLA model, and the model checkpoints/parameters are packaged together with the submitted image.
What we observed:
The reported execution time on the submission platform is around 800s before failure
In our local environment, the same pipeline finishes successfully in around 2 minutes
Inference works normally locally
There are no available logs after failure
Currently, we can only see the header information containing the team name and submitted image ID, but no actual runtime logs.
Could any administrator provide more information about possible submission restrictions, timeout limits, or ways to access detailed logs?
Thanks!
