ROS 2 TSC Contribution Report 2023-12-14.pdf (113.6 KB)
ROS 2 TSC Meeting Minutes 2023-12-14
Attendees
- TSC Members
- Community / David Lu!!
- Picknik / Henning Kayser
- eProsima / Jaime Martin Losa
- Intrinsic.ai / Katherine Scott
- Robotis / Will Son
- Foxglove / Adrian Macneil
- Community / Francisco Martin Rico
- Sony / Tomoya Fujita
- Apex.AI / Lyle Johnson, Michael Orlov
- Community / Steve Macenski
- ROS Industrial / Matt Robinson
- iRobot / Alberto Soragna
- Bosch / Christian Henkel
- Amazon / Matt Hansen
- Toyota Research Institute / Ian McMahon
- ZettaScale / Angelo Corsaro
- Canonical / Mirko Ferrati
- TSC Observers
- Bence Magyar
- Absent (Please move to TSC Members Line):
- Devcom / Jerry Towler
- Intel / Harold Lang
- Microsoft / Lou Amadio
- Intrinsic.ai / Chris Lalancette
- OSRF / Geoff Biggs
- Wind River / Andri Kholodnyi
- TSC Members
Preliminaries
- You should only have comment access to this document.
- [Kat ][1 min] Please remember to fill out your contribution report at the bottom of this document prior to the meeting.
Old business
- [Kat][5min] Welcome new TSC Members Steve Macenski and David Lu!
- [Kat][5 min] REP-2003 Vote on Draft Status Results
- Resolution passes. However we only had 12 out of 21 (57%) turn out over two weeks with two reminder e-mails.
- This literally should only take 2 minutes. Turnout should be closer to 80-90%
- TODO: request to add an abstain option on future votes
- Added to internal handbook.
- TODO: Clarify process in ROS 2 TSC charter.
- REP 1 -- REP Purpose and Guidelines (ROS.org)
- Kat has plans to meet with Chris and Geoff to clarify.
- Issue with QoSSystemDefault:
New business
- [Kat][5min] GOOD NEWS!
- We’re over the hill. ROS 2 is about 60% of all Downloads of our servers
- [Blasdel][5min] Change of representative
- Matt Hansen is now the TSC Representative for Amazon
- [Macenski][20min] New Policy for AI Generated Content in ROS Projects
- Generative AI in ROS 2 Codebases? Oh My! - ROS General - Open Robotics Discourse
- David: what are other communities doing?
- Kat: Next steps? Draft a contributing document section? Approve and then projects can optionally adopt.
- Alberto: two separate problems, legal copyright and then quality of code. First address quality then copyright.
- Kat: how does this mesh with DCO?
- Jerry: Can we lean on legal teams of TSC member organizations. My org can’t use AI gen code at all. AI can’t hold copyright in the US.
- Tyler: Stack Overflow explicitly bans all LLM generated code, they say code quality is important and LLMs are “correct looking” but incorrect. The ban users who use it.
- Adrian: autocomplete is a thing, and LLMs are no different. We’re conflating IP with quality. The risk of doing it wrong: unwelcoming community. We need to do more study in this area and see legal opinion, DCO probably covers this.
- Christian: ROS shouldn’t be first mover. Bosch is not using AI. He’s heard that orgs are providing indemnity.
- [Francisco][10min] Change Default Branch to Rolling
- Rolling as default branch - #6 by mikeferguson - ROS General - Open Robotics Discourse
- Ian – main / master is canonical approach for the default branch. Not every ROS release requires its own branch. Would
rollingbe branched off of for a release or would it be handled as a tag per release? - Tyler: rolling branch is a pain for us. ROS2 branch is used for ROS dev.
- Ian – main branch is the normal procedure so that’s what new user look for.
- Francisco – this would make a good rep
Confidential Business
- No confidential business this meeting
Recurring business
- Next ROS 2 distro release
- Chris is on vacation until the end of the year.
- Working groups [<=5 mins each]
[Bence] Control
- Successful roadmapping exercise for Jazzy
- Removing parameters/options deprecated since Humble
- Passing URDF and ControllerManager update rate to controllers now
- New acknowledgements page generated from Github data:
- rqt_jtc bugfixes for continuous joints & URDF-by-topic
- General PID controller available in Rolling
- Bugfix coming for out-of-order init calls when using URDF-by-topic with ControllerManager
- Fix a floating point comparison issue in JointTrajectoryController
[Martin Losa] Embedded
- Last meeting:
- Demo of Safe DDS running on the three cores of the AMD KR260 platform – Cortex A53, Cortex R5, and MicroBlaze FPGA-softcore, by Pablo Garrido from eProsima.
- No December meeting due to Christmas.
[Kayser] Manipulation
- API-breaking planning pipeline refactoring merged
- Multiple planners can be chained in sequence
- Continuing to see DDS issues (both FastDDS and Cyclone)
- Discussing coordinated efforts on simplifying the config and launch utils
- Node logging refactoring completed
[Woodall] Middleware
[Macenski] Navigation
- Sending goals in non-standard frames now supported
- Added soft real-time prioritization of important nodes (controller, velocity smoother, collision monitor)
- Adding collision monitor to default bringup
- Improved simulation time compliance
- Modest improved behavior in collision avoidance behavior in MPPI
[Andrei] Real-Time
[Mirko] Security
- Angelo Corsaro presented the security model of Zenoh during the monthly security WG meeting. Recording will be made available soon.
[Soragna] Production
- Defining schedule and preparing infrastructure. Meetings to start with the next year
[Orlov] Rosbag2 and Tooling
- Finally merged Make Player and Recorder Composable (rosbag2#902) Although will need to add documentation. Created a follow-up issue and draft PR. Kudos to the author and main contributor for this feature - Patrick Roncagliolo.
- Made progress on the following PRs:
