Preparing for Kinetic Sync 2020-07-21
We have 59 new and updated packages and no regressions.
I plan to hold new releases for Kinetic until Thursday and make the sync then.
If there’s anything that would be a concern with this plan please reply here.
We’re working on making the rosdistros more accurate in representing what is available. And to that end we’re implementing a new prototype tool which audits the packages released. It has identified the following packages as failing to build. Before the coming sync I plan to ticket and remove all of the following since they are not building.
They have not been flagged as a regression because most of them have never built.
Sync preparation report for kinetic
Prepared for configuration: https://raw.githubusercontent.com/ros-infrastructure/ros_buildfarm_config/production/index.yaml
Prepared for rosdistro index: https://raw.githubusercontent.com/ros/rosdistro/master/index-v4.yaml
Packages failing on all platforms
Release should be rolled back:
  • ros_cvb_camera_driver
  • rosbag_snapshot
  • sicktoolbox_wrapper
  • swarmros
Packages failing for buildfile default
Packages should be blacklisted:
Packages failing for buildfile uxhf
Packages failing for buildfile uxv8
Removing packages not building on any platform
https://github.com/ros/rosdistro/pull/25905
Blacklisting packages on specific architectures:
https://github.com/ros-infrastructure/ros_buildfarm_config/pull/178
The sync is out:
