Preparing for Indigo Sync 2017-07-24
We’re close to having another set of packages available for indigo.
Reviewing the detected regressions I found 2 root causes.
  1. jsk_apc2015_common is continuing to fail to build sourcedebs, and in recent releases it has been added as a dependency. @k-okada
  2. There is a moved header in grid_map_ros breaking cost_map_ros I’ve filed tickets upstream https://github.com/ethz-asl/grid_map/issues/111 and downstream: cost_map_ros is failing to build due to moved header · Issue #44 · stonier/cost_map · GitHub @stonier @pfankhauser
Since we have over 200 packages to sync I don’t want to wait too long we may need to sync with these regressions. Without response I may attempt to roll back the grid_map changes too.
If there’s anything else I should be aware of please reply here.
Thanks for the heads up, @tfoote! A fix for the backward compatibility for grid_map is underway: https://github.com/ethz-asl/grid_map/pull/112. I hope to get this in before the sync.
Thanks for the quick work and replies @k-okada @stonier @pfankhauser
The sync is out: New Packages for Indigo 2017-07-25 - ROS General - Open Robotics Discourse
As well as for Kinetic: New Packages for Kinetic 2017-07-25 - ROS General - Open Robotics Discourse
Re: Preparing for Kinetic Sync 2017-07-24 - Kinetic - Open Robotics Discourse
Great, I’m glad we got this resolved quickly, thank you for your work!
