I have just released version 1.3.2 of the ros_buildfarm package. I want to highlight a few items from the changelog:
- update to latest versions of Jenkins plugins (e.g. Groovy 2.0)
- fix using latest Ubuntu Docker images which don’t have
locales installed anymore
- improve reconfigure jobs performance
Happy Building!
Can you tell me if GitHub - ros-infrastructure/buildfarm_deployment still should be able to setup master/slave. Or do you have some insights on the current relationship /buildfarm_deployment ↔ /ros_buildfarm.
Greetings!
While that repository is used to provision the buildfarm machine it hasn’t been actively used for a long time. Initially we have provisioned the official buildfarm with those scripts but since then we have only updated it but never used the code to provision a new buildfarm from scratch.
Currently there is some work in progress to update the deployment code to use Xenial (rather than Trusty): Refactor for deploying a Xenial buildfarm. by nuclearsandwich · Pull Request #146 · ros-infrastructure/buildfarm_deployment · GitHub The PR is in progress though and I don’t think it is ready to be used as-is at the moment (but hopefully soon).
There are some (minor) issues with the deployment scripts and puppet files that make them not work oob, but those can be addressed / worked around. I have a fork that at least works for me. You can take a look at it and see if there’s something there you could use.
The work by Steven to migrate everything to Xenial is shaping up nicely. He’s done a good job of cleaning up the puppet files adding proper modules and refactoring.
OK thanks I will have a look at it soon. I noticed the workarounds one has to do to get it working but was wondering if I somehow managed to cause them by myself or if it was in inherent problem. Thanks for the quick answers!
