cmake ..
make -j4
sudo make install
mkdir: cannot create directory ‘build’: File exists
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
Update the VERSION argument value or use a … suffix to tell
CMake that the project does not need compatibility with older versions.
CMake Error at CMakeLists.txt:11 (find_package):
By not providing “Findgazebo.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “gazebo”, but
CMake did not find one.
Could not find a package configuration file provided by “gazebo” with any
of the following names:
gazeboConfig.cmake
gazebo-config.cmake
Add the installation prefix of “gazebo” to CMAKE_PREFIX_PATH or set
“gazebo_DIR” to a directory containing one of the above files. If “gazebo”
provides a separate development package or SDK, be sure it has been
installed.
– Configuring incomplete, errors occurred!
make: *** No targets specified and no makefile found. Stop.[quote=“Abdulazim_Israilov, post:1, topic:48361, full:true”]
cmake ..
make -j4
sudo make install
CMake.
gazeboConfig.cmake
gazebo-config.cmake
installed.
[/quote]
NOTE#I have installed the ubuntu 24.04
