Hey @Yadunund !
I am sorry to bother you, but I would like to get some clarifications about the robot’s spawn position and the initial joint angles for the qualification phase.
Here is what I understand:
- The robot’s spawn position (in the world frame) is fixed:
robot_x = -0.2,robot_y = 0.2, androbot_z = 1.14. - The initial joint angles will be such that the
target_port(which is randomized) will always be in the camera’s view.
Here are my questions:
- Are the initial joint angles for the robot fixed? Will they be the same as the home_joint_positions specified in
sample_config.yaml? - The Qualification Phase: Technical Overview document says the robot will start from a few centimeters from the target. Is there a quantitative limit for this?
