Autoware with TensorRT(CUDA, CUDNN)
Hi.
I’m trying to add my package based on TensorRT & CUDNN, but there is an cudnn link error
So I added linking option to my cmake and the error disappeared
(When I remove autoware_build_flags, there is also no build error)
But the cuda runtime error(77) occured at the moment
I also tried to build it on my own ros workspace and it works well
All the code is same and cmake option is same
I wonder why my package does not work only on the Autoware workspace
Thanks
There is one package which uses TensorRT.
It builds without problems.
Please check this file.
https://github.com/autowarefoundation/autoware/blob/master/ros/src/computing/perception/detection/lidar_detector/packages/lidar_point_pillars/CMakeLists.txt
Thanks.
I found that my memory allocation error checking was wrong.
I used assert() in my code and my workspace was built with debug type.
Sorry, I was not careful
