TurtleBot3 - Output from Intel Joule HDMI stopped working
I am working with the TurtleBot 3. The issues I am having are outlined in the following points:
Out of the box, the Intel Joule displayed correctly to a monitor.
I wanted to install Ubuntu Core on the Joule, so a BIOS update was required. To do this, I followed the instructions on https://software.intel.com/en-us/flashing-the-bios-on-joule.
Once the BIOS was flashed into the Joule, the Joule no longer displayed on the monitor (or other monitors I tried). I tried connecting the cable in different orders but it had no effect.
I reflashed the BIOS onto the Joule, with the addition of the -clear option, using the following command: Flash.bat -clear Joule_C0-X64-Release-1J2-Public_DNX.bin (suggested in https://intel-openport-v7.hosted.jivesoftware.com/thread/118328)
The Joule then connected correctly to the monitor and I was able to install Ubuntu correctly. (A second Joule I was working with experienced the same display issue; however, the above solution did not resolve it.)
This worked for a time and I was able to control the TurtleBot3 using the android app, but the Joule returned to the state where it doesn’t output from the HDMI.
I have attempted to reflash the BIOS as above, but it had no effect.
The Joule still responds when pinged as it did before the display issue rearose.
How can I resolve this issue to allow the Joule to output correctly to the monitor? Is it possible to restore the Joule to its factory settings?
Thanks for your question. However we ask that you please ask questions on
http://answers.ros.org following our support guidelines:
Support - ROS Wiki
ROS Discourse is for news and general interest discussions. ROS Answers
http://answers.ros.org/ provides a forum which can be filtered by tags to
make sure the relevant people can find and/or answer the question, and not
overload everyone with hundreds of posts.
