It’s time for another Dashing sync and patch release. This patch release will include some changes made to core packages during the last sync for our omnibus binaries on macOS, Windows, and Linux.
This patch release also includes updates to Fast-RTPS and the underlying Fast-CDR library which are not ABI compatible with the previously released version in Dashing (See [Dashing] update FastRTPS version to fix wireless communication problems by dirk-thomas · Pull Request #788 · ros2/ros2 · GitHub and [Dashing] Updating Fast-RTPS and Fast-CDR to tags by MiguelCompany · Pull Request #795 · ros2/ros2 · GitHub for details). The ROS 2 Testing repository has the updated Fast-RTPS releases available. Please report any regressions you encounter when using them before the release here.
As with the previous Dashing releases, we’re using a GitHub project board to track the release status.
The patch release board is quite full. If there is a specific pull request that is not currently on the release track as indicated by being in either the Needs Backport, Needs Release, or Released columns on the project board for this patch release which you have a strong case for backporting please let us know by commenting on the tracking issue for this patch release.
I will start holding rosdistro PRs for the sync on Tuesday 2019-10-08 so please get your releases for this sync in before then.
