Hello, I’m following the ‘Getting Started‘ instructions. I’ve set up Docker, Distrobox, Pixi, Nvidia Container Toolkit; and Workspace. Right now I’m stuck at Step 2: Start the Evaluation Container.
Everything looks good; but the last step: /entrypoint.sh ground_truth:=false start_aic_engine:=true
Looks good so far: I see Gazebo and RVix open with robot showing; in the terminal showing ‘AIC engine initialized successfully!’
And it continue ‘Starting AIC Engine Run Total Trials: 3‘ and ‘Starting trial _1‘
log: ‘No node with name ‘aic_model‘ found. Retrying… ‘ appear with some warning and other INFO.
and other a lot of INFO
with SEVERE WARNING!!! and fatal IO error,
and Aborted with EEOR; and Participand model is not ready for trial_1
with some warnings and then Trial_1 failed or was not completed. Score: 0. Then trial_2
Then: No node with name ‘aic_model’ found. Retrying… with
✗ Participant model is not ready for trial ‘trial_2’
And
Trial ‘trial_2’ failed or was not completed. Score: 0.000000. Continuing to next trial…
Trial_3 with Error
Finally Trial ‘trial_3’ failed or was not completed. Score: 0. and Show Complete Scoring Results
End with INFO and won’t exit logging.
I was supposed to continue with Step 3: Run an Example Policy. when exiting the log. But it won’t.
Can anyone feedback any clue please?
I’m on WSL2 and couldn’t active Nvidia GPU acceleration. As I know to use Nvidia GPU under WSL is different, as requires NVIDIA CUDA Toolkit inside Ubuntu instead of driver (for Windows). [xtra info]
Can anyone help please? Or this is related to WSL vs linux OS?
