In the last submission i see status ‘finished’ not ‘failed’ and some decent scores in the result file however the stdout is basically empty with also team N/A as if some error occurred in the eval vm:
AI for Industry Challenge - 2026
Date: 2026-05-07T15:07:21.641159+00:00
Team: N/A
Submission: 867
Run ID: 5e0860af-6007-45cd-9bf9-35e6b100e13c
Anyone with a similar situation?
Did you have failed submissions before this one? If yes, what did you change to get from failed → finished?
We’re stuck on the failed pattern (637s, empty stdout, result) and trying everything to break out of it.
Thanks!
no, this is literally a slightly optimized version of another policy that was fully working
We are having the exact same issue! Did anyone solve this?
I should add: it is on state FINISHED, ran a similar time than the submissions before, we get the results file where we can see that it went through all trials, but output log is empty.
same here except we had failed state, and the team name is N/A as well
Hey did you get any fix for this? We are facing the same issue. Also can we try and submit again immediately after the failed attempt?
