We have finished moving the Autoware repository to a new organisation and setting up the various processes necessary to start improving the quality of the software. The new organisation is located here:
Currently most source still lives in the autoware repository but that will change over time. The documentation is still located on the wiki of the autoware repository. It will be updated and moved to a more robust documentation system during the 1.12 cycle.
If you are looking for support for Autoware, please see this page:
https://github.com/autowarefoundation/autoware/wiki/Support-guidelines
Please note that problem solving is now done via Discourse, not the GitHub issue tracker. We will as you to post a bug report to the issue tracker if we confirm one while solving your problem.
If you are interested in contributing new features or bug fixes to Autoware, then please see this page:
https://github.com/autowarefoundation/autoware/wiki/Contributing-to-Autoware
The most important point is that your commits must now be signed-off according to the Developer Certificate of Origin. PRs that include unsigned commits will be rejected, as it is an IP risk.
We are now open for pull requests again. Thank you for your patience as we moved things around.
