Autoware.ai 1.13 is now available for general use and it’s our biggest release yet with over 230 accepted merge requests!
To install it from source, follow the building from source instructions or to run in a Docker container, see the Docker instructions.
Docker images are available at Dockerhub:
amd64 Containers
arm64 cross-compile Containers
arm64 native Containers
With either the from-source or Docker version of Autoware.ai, you can try it out using some recorded data by following this guide .
This is a list of the major changes in Autoware 1.13:
- Autoware.ai now supports the Lanelet2 mapping format! Check out the new
lanelet2aisanand all associated nodes (autoware#17) - A “Failsafe Action Framework” was implemented to handle the transition to a safe state when a system fault has been confirmed by a monitoring system which lives outside of ROS (common!40 and common#4)
- The MPC Waypoints Follower now uses qpOASES as a QP (quadratic programming) solver
rviznow has a clean, new default layout (autoware#25)- A new engage/disengage panel was added to
rvizto enable easy control of a by-wire-system interface (utilities!21) - Building your own or using existing Docker containers for Autoware.ai is now much simpler - Check out the docker repo (and specifically the
generic/build.sh,generic/run.sh, andcrossbuild/build_cross_image.shscripts) - Nightly Docker builds! (see the tags with
bleedingedge) - Full Support for ROS Melodic Morenia and C++14 (ROS Kinetic is no longer supported)
- Easy waypoint creation with the new
waypoint_creatorpackage (core_planning!15) - Numerous bug fixes and smaller changes; see the full list of changes below
There are some known issues in 1.13.
- When in Error State,
twist_gateleaks linear velocity commands - A parameter in the Emergency Handler causes it to be disabled by default
- Incorrect
assertinlidar_naive_l_shape_detectsometimes causes node to crash - Curvature calculation in
pure_pursuitis not correct
As always, the current reported issues can be viewed on the issue tracker and the current
proposed bug fixes and new features can be viewed on the merge request tracker .
And a big thanks to all the contributors, reviewers, and maintainers!
Full list of changes
autoware
- CI: Removing kinetic builds and unused Travis file.
- CI: Fixing order of PREFIX_PATH in cross-builds.
- Pin lanelet2 and Add Messages Repo Back
- Removing messages repo. Adding CUDA builds.
- Adding lanelet2 and mrt_cmake_modules to autoware.ai.repos.
- CI: Removing PYTHON_EXECUTABLE CMake arg from builds.
- Add qpOASES vendor package
- CI: Start using the bleedingedge tag for all Docker images.
- CI: Removing unused variables and combining common scripts.
- Removing files and scripts that are provided elsewhere.
common
- fix removeImpossibleCandidate function for reverse order
- fix visualization of empty lanelet map
- fix exit condition when error exists during parsing
- Revert “new feature:emergency handler is added”
- Fix time error
- CI: Dropping Kinetic builds.
- change class name from SHM_VitalMonitor to ShmVitalMonitor not to use underscores to be compliant with ROS guide line
- add function: getIntersect
- add wayarea2grid_lanelet2 node to object_map package
- Add node_status_monitor
- Add value_manager for health_checker
- add two tests related to callbacks and fix one issue found by the added tests. Issue: error is detected if system_status is not received for more than 0.1s (expectation is to receive every 33ms), that could occur during normal initiazliation. CM is to start error detection logic once one system_status is received
- [#23] clean up CMakeLists.txt and package.xml -Clean up all CMakeLists.txt Files in Stack (#23) · Issues · Autoware Foundation / MovedToGitHub / autoware · GitLab
- add stop_sign_id argument to stopSignsStopLines function
- Improve check function in health checker
- change arguments to const ref for fromBinMsg
- Remove rosparam enable_statistics
- Fix CMakeList
- Replace and add emergency category
- shared_ptr was abolished and replaced with unique_ptr.
- fix matchWaypointAndLanelet
- Rename health checker library and move directory
- rename lanelet2_msgs to autoware_lanelet2_msgs in lanelet2_extension package
- Standardize build_depends.repos
- Add function identifying lane direction in libwaypoint_follower
- add lanelet2_map_loader and lanelet2_visualization
- add lanelet2_extension package
- move core nodes of waypoint_follower to planning, add libwaypoint_follower packages
- change CMAKE_CXX_FLAGS option from c++11 to c++14
- add wf_simulator codes
- README and add DCO
- mpc_follower: add qpoases related code
- Maint/ci improvements
- add function for last waypoint control
- Adding startup params to some nodes.
- Updates package.xml Files to Format 2
- Maint/ci optimization
core_perception
- Add rostest of launching ndt_matching
- Fixing unit test values in gnss_localizer Due to Fix in Common
- add vel_pose_diff_checker
- fixed to ground filter in base_link
- Update README.md
- modify default value
- add imm_ukf_pda_track_lanelet2 node
- modified for TwistWithCovariance input output
- CMakeLists.txt fixes
- add feat_proj_lanelet2 node
- apply clang format
- Standardize and fix build_depends.repos
- Change the key format so that it can be managed with yaml.
- Fix topic name for rate checker
- Fix issue with incorrect initial orientation
- fixex concurrency issue in openmp impl of ndt matching
- Clean-up/Lint Traffic Light Recognizer (TLR)
- changed to handle use_odom & use_imu
- Fixes missing qpoases_vendor dependency for common.
- Adding tests. Implementing different method to fix GGA and RMC messages.
- Apply same fix to GPRMC.
- Fixing bug where nmea2tfpose would always return positive coordinates.
- gnss fitness score made configurable through launch file
- Tracker: Unused param cleanup
- CI: Starts using the bleedingedge tag for all Docker images.
- Fixes location of remap in naive_motion_predict launch file.
- Updating all package.xml files to format 2 (REP-140).
- Add note to README
- Remove dead code
core_planning
- fix tranformation of crosswalk polygon
- Fix twist_cmd safety checking in planner
- Fix local closest waypoint in astar_avoid
- Apply to negative velocity
- add disable insert stop line function
- Add ROS Observer to core_planning
- fix initial value of twist_gate parameter “is_state_drive” to false from true
- Apply negative velocity to pure_pursuit
- add test case for emergency vehicle cmd and fix issues(reset emergency flag in reset_vehicle_cmd_msg and publish vehicle cmd in emergency_cmd_callback)
- add lanelet2 option to decision_maker
- remove unused arg
- Apply negative velocity to velocity_set
- Add timer callback
- add delay compensation
- add velocity_set_lanelet2 node to waypoint_planner package
- waypoint_creator: fix transform for deletePoseCallback
- add costmap_generator_lanelet2 node to costmap_generator package
- add lane_rule_lanelet2 node to lane_planner package
- Cleaning up all CMakeLists.txt files.
- Removing unecessary _INCLUDE_DIRS from all packages.
- Clean up and fix twist_gate CMakeLists.txt.
- Apply negative velocity to lane_select
- Apply negative velocity to waypoint_replanner
- Apply negative velocity to lane_rule
- Fix the Way waypoint_replanner and twist_gate Check for decision_maker
- Standardize and fix build_depends.repos.
- Fix mistakes in specifying test package names
- remove unused code
- fix launch file
- fix include error
- remove waypoint_follower
- move twist_gate
- move twist_filter
- move pure_pursut
- move mpc_follower pkg
- change dependency from waypoint_follower to libwaypoint_follower
- wf_simulator: change /vehicle_status/angle definition from handle angle [deg] to tire angle [rad]
- waypoint_follower: change /vehicle_status/angle definition from handle angle [deg] to tire angle [rad]
- Changes to waypoint_follower from 1.11.0.
- Feature/Gitlab CI& move pkgs (#2)
- Fix wp_replanner bug that the first config callback is not applied.
- add waypoint_creator package
- CI: Applying optimization changes from other repos.
- Updates all package.xml files to Format 2.
docker
- Adding qpoases-vendor to list of dependencies for Docker.
- Adding joint_state_publisher as dependency.
documentation
- Updating demo launch files after split of waypoint_follower.
- fix cosmap topic name
- fix rviz config
- update default distro to melodic
- add a cross-dependencies file for dependencies in the cross-build environments
- Automated Docker Builds
- CI: sets scripts to report an error code on failure
- Changing cross-build builder FROM to ros image.
- Standardizing build_cross_image.sh to match build.sh and run.sh.
- Fixing dependencies outside of build context with temporary copy.
- Add -v flag to build specific version of Autoware
- Fix cross-build bug
- Fix multiple issues in build.sh, run.sh, and entrypoint.sh.
- Add Dockerfile linting
drivers
- Update ssc_interface to be platform independent
- SSC Interface: Change VelocityAccel to VelocityAccelCov.
- CI: Dropping Kinetic builds and removing unused Travis file.
- Add vehicle driver(AS and YMC) vital monitoring via ROS Observer
- Removing unecessary dependency in build_depends.repos.
- AS Interface: Reduced default decel limit to 3.0.
- CI: Removing messages repo. Adding CUDA builds.
messages
- Lateral limitation filter by twist_filter
- add param of decision_maker: disable insert stopline
- add parameters for MR 30
- Rename lanelet2_msgs to autoware_lanelet2_msgs
- Adding service message for TF-based TLR
- Initial commit
- Updates package.xml files to Format 2.
- Bumping package versions for release to ROS.
- Updating CHANGELOG files for 1.12.0 ROS release.
- Adding CHANGELOG for autoware_external_msgs and autoware_map_msgs.
- Updating autoware_map_msgs version for ROS release.
simulation
- fix launch typo
- fix launch file
- move wf_simulator
- add wf_simulator pkg
utilities
- Fix wf_simulator’s parameter name in runtime_manager
- fix rviz config
- rename
- Add appropriate description.
- add checkbox param of decision_maker
- add use_ll2 option to lane_rule
- add use_ll2 option to feat_proj node
- add use_ll2 option to wayarea2grid
- modify concentric_divider_distance value
- add use_l2 option to imm_ukf_pda_track
- add use_ll2 option to decision_maker
- remove unused arg & add used arg in runtime manager mpc_follower
- add use_ll2 option to velocity_set
- add use_ll2 option to costmap_generator
- modify GUI for ekf twist_with_covariance
- CMakeLists.txt fixes.
- add parameters for MR30
- Change latch option for /vehicle/engage
- Adding twist2odom node.
- Add lanelet2aisan converter
- add lanelet2_loader to runtime manager
- modify runtime manager
- add params in runtime_manager for topic name
- modify runtime_manager for waypoint_creator
- runtime_manager: add parameter for mpc_follower
- modify computing.yaml for wf_simulator
- add parameter for adding virtual end waypoints on runtime manager
- add parameter for steering offset estimate on runtime manager
- add vehicle engage panel
- Avoid accessing method in name_get and name_get_cond
- register camera_id at startup of calibration publisher
- runtime_manager: Add missing dependency python-psutil
visualization
- Added missing dependency
- Add vehicle_info.yaml for g30esli
