Hi ROS Community,
I’ve been working on an open-source transport prototype pairing Eclipse Zenoh with RaptorQ (RFC 6330) fountain codes, designed around the constraints of outdoor ground robots (such as mowers and agricultural rovers) operating in non-line-of-sight (NLOS) conditions.
The Problem
When ground vehicles operate across large outdoor sites with foliage, structures, or rolling topography, wireless links frequently experience sustained packet loss (15–30%).
When this occurs, reliable retransmissions quickly trigger head-of-line blocking—trapping urgent commands and telemetry behind stalled bulk data (like costmaps or boundary files).
How the Prototype Works
- Fountain Coding: Bulk assets are compressed and partitioned across interleaved RaptorQ source blocks. The receiver can reconstruct the bit-exact payload once any sufficient set of droplets arrives, eliminating round-trip retransmission overhead.
- Airtime Pacing: Map streaming is rate-limited via a token bucket (defaulting to 128 kbps to match sub-GHz telemetry links) using Zenoh’s Priority.DATA_LOW and CongestionControl.DROP.
- Command QoS: Signed Ed25519 commands bypass background map traffic by using Priority.DATA_HIGH and CongestionControl.BLOCK.
- Edge Storage: Droplets append asynchronously with batched disk commits to avoid I/O stalls on embedded flash media.
Running the Simulation
You can test two peers communicating over a simulated 25% packet-loss link locally:
git clone https://github.com/oceans-niagara/zenoh-fountain-transport
cd zenoh-fountain-transport
pip install eclipse-zenoh raptorq cryptography cbor2
python demo.py
Expected output:
Original Size : 158,500 bytes
Compressed Size : 36,042 bytes
CID (SHA-256) : 7d4a2e...
RFC 6330 Blocks : 3 Source Blocks (Interleaved)
Total Droplets : 111
Streaming interleaved droplets across Zenoh (simulating 25% radio drop)...
Ingested: 83, Dropped: 28
Broadcast Duration: 3.82s
Solved Blocks: 3 of 3
Assembly & Hash Time: 0.62 ms
Security: SUCCESS (Ed25519 whitelisted command delivered via Zenoh DATA_HIGH)
Status: SUCCESS (Multi-block bit-exact match, 0 retransmissions)
Seeking Community Feedback
- Integration Architecture: Would this be most useful packaged as an external Zenoh transport daemon/bridge, or as a native ROS 2 node wrapping types like nav_msgs/OccupancyGrid?
- Sub-GHz Radio Behavior: For those running 900 MHz radios (e.g., RFD900 or Digi) or 802.11ah, is application-level token bucket pacing sufficient, or does native link-layer MTU batching provide measurable benefits without increasing command latency?
- Loss Traces: If your team has real-world packet loss profiles or pcap logs from degraded field links, I’d be interested in testing against those traces.
Repository (Apache 2.0): Oceans-Niagara/zenoh-fountain-transport
I would appreciate any critique, architectural thoughts, or advice from anyone dealing with tricky outdoor links.
Thanks,
Perry
