# The easiest way to deploy a custom package?
**URL:** <https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893>\
**Category:** ROS General\
**Created:** [February 10, 2021, 10:38am UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893 "2021-02-10T10:38:33Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![msadowski](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/msadowski/32/33950_2.png) [@msadowski](https://discourse.openrobotics.org/u/msadowski)\
**Post date:** [February 10, 2021, 10:38am UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893/1 "2021-02-10T10:38:33Z")
</div>
Hi!
I’ve been doing quite a bit of research on this but still couldn’t figure out the best way to approach package deployment.
To better paint a picture imagine a robotics company with 3 software engineers that need to supply robots with their packages that can’t be open sourced. Let’s assume we deal with around 30 packages.
The first thing I looked at was the buildfarm tutorials, however spinning up 3 Amazon instances sounds like an overkill for such a low amount of packages, especially given the small amount of developers.
What is your experience with these things? So far, apart from buildfarm repos, I’ve come across ros\_bundling, [aws\_robomaker](https://docs.aws.amazon.com/robomaker/latest/dg/deployment.html).
Does anyone have tips on what I could explore? I’m ideally looking at the least friction method that won’t require too much maintenance. Any tips/repos/tutorials would be highly appreciated!
Thanks!
**Author:** ![Jeremie](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/jeremie/32/1094_2.png) [@Jeremie](https://discourse.openrobotics.org/u/Jeremie)\
**Post date:** [February 10, 2021, 1:40pm UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893/2 "2021-02-10T13:40:43Z")
</div>
Have you considered [snaps](https://snapcraft.io/docs/ros-applications)? They are an easy way to distribute self-contained applications, including ROS 1/2 stacks. As an example, find [here](https://ubuntu.com/blog/how-to-set-up-turtlebot3-in-minutes-with-snaps) a short blog post series on creating a Snap for the TurtleBot3.
**Author:** ![Loy](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/loy/32/3182_2.png) [@Loy](https://discourse.openrobotics.org/u/Loy)\
**Post date:** [February 10, 2021, 2:21pm UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893/3 "2021-02-10T14:21:26Z")
</div>
Years ago I looked into making apt/.deb packages with `bloom` and hosting them via IIRC [aptly](https://www.aptly.info/). Never fully made it to production use for various non-technical reasons.
**Author:** ![peci1](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/peci1/32/10145_2.png) [@peci1](https://discourse.openrobotics.org/u/peci1)\
**Post date:** [February 10, 2021, 2:56pm UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893/4 "2021-02-10T14:56:11Z")
</div>
Deb packages using Bloom are certainly one way to go. Bloom can generate them automatically from any ROS package. And you don’t have to upload them anywhere, they’re just built locally on your machine. Then you can decide if you want to spin up a local APT repo or just distribute the packages via rsync or similar ways. We did this (with the custom APT repo) with one package that was difficult to build so that developers have easier lives…
You could also store the contents of your workspace’s install directory on some network location and just rsync all of its contents to the robots. That would also work (assuming you have a way of installing additional dependencies, i.e. calling rosdep install after rsync).
**Author:** ![flixr](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/flixr/32/142_2.png) [@flixr](https://discourse.openrobotics.org/u/flixr)\
**Post date:** [February 10, 2021, 7:37pm UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893/5 "2021-02-10T19:37:33Z")
</div>
What works quite well for us is to build debs using just cmake/cpack and upload them to aptly repos (mostly a release and a testing repo).
So essentially for all our packages (most of them ROS independent packages/libs) we just run `make package`, upload them to the aptly repo (from CI) and then have a “simple text file” with exact versions of these debs (that basically form a “distribution”) that we install to the devices/robots (or bake into an installable image).
Obviously there is some convenience tooling around it, but that’s basically it…
To build debs with cmake we have a simple package.cmake file that we always include (for ROS and non-ROS packages).
See e.g. [rc\_genicam\_camera/cmake at master · roboception/rc\_genicam\_camera · GitHub](https://github.com/roboception/rc_genicam_camera/tree/master/cmake)
No need for the roundtrip with bloom or catkin/colcon for these individual packages.
Obviously this approach also has it’s drawbacks, but for our use-case it works pretty well.
**Post date:** [February 11, 2021, 4:45pm UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893/6 "2021-02-11T16:45:28Z")
</div>
Thanks for the ideas so far!
@Jeremie I’ve looked breifly into Snap around 3 years ago. Back then I remember having some issues with sandboxing, especially around device access. I think it might be worth taking another look at it.
@Loy @peci1 thanks for the recommendation! I’ve just checked bloom and it seems quite easy to create a .deb assuming I can resolve the dependencies. I will definitely give this approach a shot first.
@flixr thanks for sharing your approach! I’ll give this a shot once I figure the optimal workflow with debs and aptly. I certainly like the idea of setting this up once for every package and not having to think too much about it.
**Post date:** [February 11, 2021, 5:00pm UTC](https://discourse.openrobotics.org/t/the-easiest-way-to-deploy-a-custom-package/18893/7 "2021-02-11T17:00:50Z")
</div>
Feel free to reach out if you have any question and/or encounter any difficulties 👍
