Package: tecgihan_driver
Distro: Humble (Ubuntu Jammy, amd64)
The binary build for tecgihan_driver 0.2.0 succeeded on 2026-07-08:
(version: 0.2.0-1jammy.20260708.091808)
However, the downstream job Hrel_sync-packages-to-testing_jammy_amd64
is showing as failed, and the package has not appeared in the public
apt repository even after more than a week.
apt-cache madison ros-humble-tecgihan-driver still only shows:
0.1.2-1jammy.20260605.142732
Could someone take a look at why the sync job is failing?
It’s possible this is related to geometry_msgs also failing to build
(Hbin_uJ64__geometry_msgs__ubuntu_jammy_amd64__binary), which may be
blocking the sync.
Thank you.
