# Survey - Simulation in Robotics Development
**URL:** <https://discourse.openrobotics.org/t/survey-simulation-in-robotics-development/13356>\
**Category:** ROS General\
**Tags:** gazebo, simulation\
**Created:** [March 23, 2020, 4:48pm UTC](https://discourse.openrobotics.org/t/survey-simulation-in-robotics-development/13356 "2020-03-23T16:48:41Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![kondurivamshi](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/kondurivamshi/32/5931_2.png) [@kondurivamshi](https://discourse.openrobotics.org/u/kondurivamshi)\
**Post date:** [March 23, 2020, 4:48pm UTC](https://discourse.openrobotics.org/t/survey-simulation-in-robotics-development/13356/1 "2020-03-23T16:48:41Z")
</div>
Hello all,
We at AWS RoboMaker are interested in feedback from the community on simulation in robotics development to help us learn more about the needs, pain-points and usage seen in this space. We’d greatly appreciate it if you can fill out the survey below.
[Click here for the survey](https://tinyurl.com/rr6amyh)
It takes less than 3 minutes to complete, and we will keep the link open for a couple weeks at-least.
Thanks,
Konduri Vamshi
**Author:** ![Katherine\_Scott](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/katherine_scott/32/4434_2.png) [@Katherine\_Scott](https://discourse.openrobotics.org/u/Katherine_Scott)\
**Post date:** [March 23, 2020, 4:50pm UTC](https://discourse.openrobotics.org/t/survey-simulation-in-robotics-development/13356/2 "2020-03-23T16:50:08Z")
</div>
Do you intended to open source the results?
**Post date:** [March 23, 2020, 5:41pm UTC](https://discourse.openrobotics.org/t/survey-simulation-in-robotics-development/13356/3 "2020-03-23T17:41:43Z")
</div>
@Katherine_Scott. Yes! We will be open sourcing the results after consolidating it.
**Post date:** [May 20, 2020, 4:01pm UTC](https://discourse.openrobotics.org/t/survey-simulation-in-robotics-development/13356/5 "2020-05-20T16:01:29Z")
</div>
Hello, we had 85 responses to the survey. Full results can be found in the pdf here! Thank you for your participation.
[Simulation in Robotics\_survey\_results.pdf](https://discourse.openrobotics.org/uploads/short-url/ngI2Rt2E0DyTRs6l7eQzsddw6X4.pdf) (165.1 KB)
