Hi Open-RMF team,
I am currently investigating the Beacon functionality in Open-RMF / RMF Web, especially rmf_fleet_msgs/BeaconState and the beacon_state topic.
I found the BeaconState message definition, the beacon handling code in rmf-web, and some unit tests for the beacon dashboard components. However, I could not find documentation explaining how extensively the Beacon functionality has actually been tested or used.
I would like to clarify the following:
Have Beacons in Open-RMF been tested?
If yes, which parts of the Beacon functionality have been tested? -
Was the complete flow tested end-to-end?
For example:Beacon / publisher → ROS 2 BeaconState → RMF → RMF Web API → Dashboard -
Were real physical beacon devices used during testing, or were only simulated/mock BeaconState messages used?
What was the original intended use case for Beacons in Open-RMF?
For example, were they intended for emergency alerts, audio/visual indicators, robot-mounted beacons, building infrastructure, or something else? -
Is there any real deployment or demo where Beacons have been used?
If so, is the code or documentation for that implementation publicly available? -
What is the current reliability/status of the Beacon implementation?
Would you consider the current Beacon code:- production-ready,
- usable but experimental,
- partially implemented,
- deprecated / no longer maintained?
Is it currently recommended to build a new system using
BeaconState, or would the Open-RMF team recommend another mechanism instead? -
Are there any known limitations or unfinished parts of the Beacon implementation that users should be aware of?
Any documentation, examples, test results, previous deployments, or related issues/PRs would be very helpful.
Thank you!
