Space Station OS v0.9.0 released — ROS 2 Jazzy, Pixi, and a new development baseline
We are pleased to announce the release of Space Station OS v0.9.0.
Demo video: https://www.youtube.com/watch?v=O37aDPzUH4w
Space Station OS (SSOS) is an open-source ROS 2–based platform for simulating, integrating, and operating the subsystems of a crewed space station.
v0.9.0 is a major integration milestone for the project. It establishes a new public and development baseline as we continue toward v1.0.
ROS 2 Jazzy and Ubuntu 24.04
The native development and system-integration baseline is now:
  • Ubuntu 24.04
  • ROS 2 Jazzy
This gives SSOS a common modern ROS 2 environment for continued subsystem and system-level development.
Reproducible development with Pixi and RoboStack
SSOS now provides a reproducible ROS 2 Jazzy development and runtime environment through Pixi and RoboStack.
A typical setup is:
git clone https://github.com/space-station-os/space_station_os.git
cd space_station_os
pixi install --locked
pixi run build
pixi run test
pixi run station
This allows users to run and develop SSOS without requiring a system-wide ROS 2 installation.
Native Ubuntu 24.04 / ROS 2 Jazzy development remains supported for system integration and contributors who prefer a native ROS environment.
Ubuntu Desktop application
v0.9.0 also introduces a Tier-1 Ubuntu Desktop application path.
After initial installation, users can launch the full Space Station OS mission-control stack from a desktop shortcut without directly using ROS launch commands.
The goal is to make SSOS easier to explore while keeping the underlying ROS 2 architecture fully accessible to developers.
New SSOS architecture
v0.9.0 also establishes the foundation of the new SSOS system architecture.
This includes:
  • ssos_core for system-level management and subsystem registration
  • ssos_sim for simulation control, world state, simulation time, and fault injection
  • shared system-level ROS 2 interfaces
  • subsystem lifecycle, heartbeat, telemetry, and fault handling
  • an integrated Mission Control GUI
  • clearer separation between subsystem logic and ROS-specific integration
ECLSS serves as the first major reference implementation of this architecture.
Legacy space_station_* packages remain available during the migration and will be progressively reorganized into the new architecture.
Validation
The v0.9.0 Pixi baseline was validated with:
  • 144 tests
  • 0 failures
  • 0 errors
  • 0 skipped tests
Dedicated CI paths are provided for native ROS 2 Jazzy and the locked Pixi environment.
What comes next
v0.9.0 is not the end of the architecture work.
It is the baseline from which we are now expanding EPS, Thermal, GNC, and other subsystems toward a common station-level architecture.
The goal is to move from parallel subsystem demonstrations toward one extensible and configurable Space Station OS.
Links
Repository:
v0.9.0 release:
Project discussions:
We welcome feedback, technical discussion, testing, and contributions from the ROS community.
Thank you to everyone who has helped move Space Station OS forward.
Congrats on the v0.9.0 baseline — the split into ssos_core / ssos_sim, plus subsystem lifecycle, heartbeat, telemetry, and fault injection, is the part I’m reading most carefully.
On a small Jetson + arm stack we work on (projectEDGE / EDGE-teach), the seam we care about is the same shape: after a heartbeat loss or a fault-injection trip, the subsystem must leave the command path, while telemetry is still allowed to flow on a separate lane. Model / skill packs only emit candidates; they never own the actuation bus. A fixed hardware envelope (workspace, gripper torque / position bounds, hold-load stop) and install / runtime gates reject out-of-envelope params instead of silently clipping. Empty-grasp / backoff comes from sensors and present-load, not from model text.
Curious how SSOS draws that line today in the new architecture (ECLSS as the reference is a good place to look): on heartbeat loss or a sim-injected fault, does the subsystem get dropped from the command / Mission Control path while its telemetry channel stays up, or do command and telemetry share one lifecycle gate? And when a fault is cleared, what re-admits the subsystem to the command path — an explicit owner / operator ack, or automatic recovery inside the subsystem?
Not claiming we run SSOS in production — just adjacent safety-envelope work, and your v0.9.0 write-up maps cleanly onto the propose≠own-bus cut we keep hitting.
— Owen (ouxuedong)
