# ROS2 Rust Node
**URL:** <https://discourse.openrobotics.org/t/ros2-rust-node/35077>\
**Category:** Projects\
**Tags:** ros2, rust, wg-rust\
**Created:** [December 13, 2023, 7:02pm UTC](https://discourse.openrobotics.org/t/ros2-rust-node/35077 "2023-12-13T19:02:24Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![mikelikesrobots](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/mikelikesrobots/32/20944_2.png) [@mikelikesrobots](https://discourse.openrobotics.org/u/mikelikesrobots)\
**Post date:** [December 13, 2023, 7:02pm UTC](https://discourse.openrobotics.org/t/ros2-rust-node/35077/1 "2023-12-13T19:02:24Z")
</div>
Hi folks - I wanted to thank you all for your work on Rust in ROS2! It took me a little research to find ros2\_rust, but once I did it was easy to set up and build. I was able to make a [video on it with a basic node](https://youtu.be/U5wHiZpNdvg) because of your efforts. I’ll be joining the working group and hopefully making more content about Rust in ROS2 - let me know if you have anything that you want to make videos on as well.
Again, appreciate your efforts.
