# ROS2 Foxy Zerotier VPN problems update
**URL:** <https://discourse.openrobotics.org/t/ros2-foxy-zerotier-vpn-problems-update/39480>\
**Category:** ROS General\
**Tags:** ros2, foxy, vpn\
**Created:** [September 5, 2024, 1:03pm UTC](https://discourse.openrobotics.org/t/ros2-foxy-zerotier-vpn-problems-update/39480 "2024-09-05T13:03:05Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![maurtonio](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/maurtonio/32/13257_2.png) [@maurtonio](https://discourse.openrobotics.org/u/maurtonio)\
**Post date:** [September 5, 2024, 1:03pm UTC](https://discourse.openrobotics.org/t/ros2-foxy-zerotier-vpn-problems-update/39480/1 "2024-09-05T13:03:05Z")
</div>
I’m having some issue with my robot ecosystem and the remote connection.
The ecosystem is composed by:
A rover where is running ROS 2 foxy connected to a router
The router where is enabled a connection to a Zerotier VPN net
A ROS 2 foxy remote host connected to the same VPN net of the router
Based on these info, the rover is not directly connected to the VPN, the router will bridge remote connection from host connected to the same VPN net of the router.
In this VPN net the router and the remote host have, for ex, an ip class like this 10.10.10.x, instead the rover in the router net has an ip class like this 192.168.1.X
For ROS 1 the thing was easy having the ROS\_MASTER on the rover.
The thing on ROS 2 is not working, even if i set the ROS\_DOMAIN\_ID to the same number on both, rover and remote host, i can’t list nodes, echo topics created on the rover and other stuff to manage it.
Of course I can ping and ssh connect to the rover from the remote host without problems
To ssh i use
> ssh rover@192.168.1.X
If from the host i run a simple publisher
> ros2 run my\_py\_package publisher\_class\_py\_node
and on the rover if i run
> tcpdump -i ztzlgp434l -n udp
where ztzlgp434l is the rover net interface for the zerotier, i can clearly see the packet arriving and it stops when i kill the node on the host
I also tried to export
> export RMW\_IMPLEMENTATION=rmw\_fastrtps\_cpp export
> FASTRTPS\_DEFAULT\_PROFILES\_FILE=$HOME/custom\_profile.xml
with a custom profile like this
\<?xml version="1.0" encoding="UTF-8" ?\> udpv4\_transport UDPv4
    <participant profile_name="vpn_profile" is_default_profile="true">
        <rtps>
            <userTransports>
                <transport_id>udpv4_transport</transport_id>
            </userTransports>
            <useBuiltinTransports>false</useBuiltinTransports>
            <defaultUnicastLocatorList>
                <!-- Specify the VPN IP of the local machine -->
                <locator>
                    <kind>UDPv4</kind>
                    <address>ROBOT_IP</address> <!-- For the robot machine -->
                    <port>7400</port> <!-- Default discovery port -->
                </locator>
            </defaultUnicastLocatorList>
            <builtin>
                <initialPeersList>
                    <!-- Specify the VPN IP of the other machine -->
                    <locator>
                        <kind>UDPv4</kind>
                        <address>HOST_IP</address> <!-- For the host machine -->
                    </locator>
                </initialPeersList>
                <metatrafficUnicastLocatorList>
                    <locator>
                        <kind>UDPv4</kind>
                    </locator>
                </metatrafficUnicastLocatorList>
            </builtin>
        </rtps>
    </participant>
</profiles>
but it gives me parse errors.
What I’m sure about is that the rover receives the packet through UDP, but there’s something wrong to recognize them.
Do you have any advise/suggestion to make it work?
I’m not doing anything special on the rover, I just launch a couple of ROS 2 packages for PCL and lidar managing, nothing more
**Author:** ![gbiggs](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/gbiggs/32/30361_2.png) [@gbiggs](https://discourse.openrobotics.org/u/gbiggs)\
**Post date:** [September 5, 2024, 11:19pm UTC](https://discourse.openrobotics.org/t/ros2-foxy-zerotier-vpn-problems-update/39480/2 "2024-09-05T23:19:52Z")
</div>
Thanks for your question. However we ask that you please ask questions on [Robotics Stack Exchange](https://robotics.stackexchange.com/) following our [support guidelines](http://wiki.ros.org/Support).
ROS Discourse is for news and general interest discussions. [Robotics Stack Exchange](https://robotics.stackexchange.com/) provides a Q&A site which can be filtered by tags to make sure the relevant people can find and/or answer the question, and not overload everyone with hundreds of posts.
**Post date:** [September 6, 2024, 7:17am UTC](https://discourse.openrobotics.org/t/ros2-foxy-zerotier-vpn-problems-update/39480/3 "2024-09-06T07:17:49Z")
</div>
Thank you for the advice, I already did it. Sorry for my post here, hoping that someone can help me
**Author:** ![MoffKalast](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/moffkalast/32/6355_2.png) [@MoffKalast](https://discourse.openrobotics.org/u/MoffKalast)\
**Post date:** [September 6, 2024, 12:58pm UTC](https://discourse.openrobotics.org/t/ros2-foxy-zerotier-vpn-problems-update/39480/4 "2024-09-06T12:58:15Z")
</div>
Yeah that’s pretty common for fastdds’s simple discovery, I’ve never really managed to get it working reliably beyond localhost. If your platform has enough oomph to use cyclone, then that’s probably the best bet, otherwise you can try emulating a ROS 1 setup using a[fastdds discovery server](https://fast-dds.docs.eprosima.com/en/latest/fastdds/ros2/discovery_server/ros2_discovery_server.html), which [conceptually acts like a roscore](https://www.reddit.com/media?url=https%3A%2F%2Fi.redd.it%2Fcyio8cs7lmec1.png). It also reduces multicast traffic since there’s no need for nodes to discover each other anymore which is a big plus for this sort of tunneling with limited bandwidth.
