ROS PMC Minutes for October 27, 2026
The ROS PMC meeting for this week was on Tuesday, October 27, 2026. The notes from the meeting are available at ROS PMC weekly meeting agenda.
ROS PMC Business
  • :white_check_mark: Two asynchronous votes under Charter Article 4.12.ii have closed. Six of the seven items passed by a 2/3 majority (at least 14 of 20 PMC Constituents).
    • New committers:
      • :white_check_mark: Tim Clephas (“Timple”) - 15 / 20, passed
      • :white_check_mark: Nadav Elkabets - 14 / 20, passed
      • :white_check_mark: @KimMcG - 15 / 20, passed
      • :white_check_mark: Martin Pecka - 14 / 20, passed
      • :white_check_mark: @nvcyc - 14 / 20, passed
      • :white_check_mark: Leonardo Rossetti - 12 / 20 passed
    • :white_check_mark: Motion regarding @skye.galaxy - 16 / 20, passed
Regular Business
Buildfarm update
The buildfarm builds and tests ROS packages across all supported distributions and platforms. This section covers new issues, current priorities, and infrastructure changes that affect maintainers.
  • :new_button: Issues:
    • rmw_cyclonedds_cpp build emits a -fvisibility-inlines-hidden warning when compiling C code. Missing backport.
    • Windows build warns about exceeding the CMake object file path length in rosbag2_performance_benchmarking_msgs.
    • Build warning: __builtin_memmove out of bounds in test_buffer.cpp under GCC 15.
    • Intermittent Windows failures in the type description service and parameter events tests with Connext DDS.
  • :warning: Priorities:
Waffle note-taker
Rosdistro assignments
Rosdistro is a weekly assignment to monitor incoming issues and pull requests in GitHub - ros/rosdistro. Two people per week are assigned to be the rosdistro maintainers.
Release Management
Release Management tracks the status of upcoming releases, patches, and syncs across the active ROS distributions.
  • Christophe Bédard (Humble)
    • No update in the agenda.
  • @yadunund (Rolling)
  • Marco A. Gutiérrez (Jazzy)
  • @cottsay (Kilted)
    • :warning: Build regression in many small packages.
  • @sloretz (Lyrical)
Working Group Updates
  • ROS Office Hours
    • Last Meeting: Oct 23, 2026
    • Next Meeting: [DATE]
  • Client Library Working Group (Alberto Soragna)
    • Last Meeting: Oct 16, 2026
    • :date: Next Meeting: Oct 30, 2026
    • Items on the agenda:
      • Callback event executor bugs
      • Clock jumping backwards
  • Accelerated Memory Transport Working Group (@ahcorde)
    • Last Meeting: Oct 14, 2026
    • :date: Next Meeting: Oct 28, 2026
    • Topic: AMD
  • ROSGraph Working Group (Emerson Knapp)
    • Last Meeting: [DATE]
    • Making progress on NoDL, targeting M-turtle.
    • generate_parameter_library is moving to this group.
  • SIG Physical AI (@yadunund)
    • :new_button: 3 new members.
    • :warning: Direction change: the working groups will be folded into a single group effort, with work packages and tickets for Application 3.
    • Progress:
      • Intel added its own rosidl::Buffer backend.
      • tensor_msgs is getting a REP.
      • WG4 is reorganizing the demos repo and building calibration and ONNX inference nodes.
      • Nvidia presented its LEAPP policy deployment workflow to WG3. It reinforces the need for a data collection and inference contract, which WG3 and WG4 will align on.
Agenda
  • [@claraberendsen] rclpy#1707: Migrate from pybind11 to nanobind
  • [@clalancette] Less is more: remove CI jobs
    • :white_check_mark: xfail jobs removed in ci#913.
    • :white_check_mark: Coverage jobs removed in ci#915.
  • [Michel Hidalgo] REP-0157: Minimal Overhead Messaging Support Using Runtime Agnostic Memory Layouts
    • :date: This gets its own dedicated meeting on Wednesday, Nov 4, 2026.
  • [@cottsay] “Formal” policy for platform-specific review of rosdep rules
    • Platforms listed: OpenEmbedded, Red Hat / Fedora, NixOS.
  • [@mjcarroll] Ruff
    • :light_bulb: @mjcarroll suggested using Ruff instead of flake8 and pep257.
    • :warning: The version of Ruff in Ubuntu is old.
