# ROS 2 Rust Meeting: November
**URL:** <https://discourse.openrobotics.org/t/ros-2-rust-meeting-november/40489>\
**Category:** ROS General\
**Tags:** ros2, rust, wg-rust\
**Created:** [November 8, 2024, 12:38pm UTC](https://discourse.openrobotics.org/t/ros-2-rust-meeting-november/40489 "2024-11-08T12:38:58Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![jhdcs](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/jhdcs/32/8074_2.png) [@jhdcs](https://discourse.openrobotics.org/u/jhdcs)\
**Post date:** [November 8, 2024, 12:38pm UTC](https://discourse.openrobotics.org/t/ros-2-rust-meeting-november/40489/1 "2024-11-08T12:38:58Z")
</div>
The next ROS 2 Rust Meeting will be 2024-11-11T14:00:00Z
The meeting room is _tentatively_ at [https://meet.google.com/xrf-pzbg-mtj](https://meet.google.com/xrf-pzbg-mtj), however, we’ve had technical difficulties getting rooms up and running. If the room needs to change, we will update this thread with the new info!
**Author:** ![maspe36](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/maspe36/32/19555_2.png) [@maspe36](https://discourse.openrobotics.org/u/maspe36)\
**Post date:** [November 11, 2024, 3:44pm UTC](https://discourse.openrobotics.org/t/ros-2-rust-meeting-november/40489/2 "2024-11-11T15:44:56Z")
</div>
Here are my rough notes
## Attendees
- Sam Privett
- Esteve Fernandez
- Grey M
- Luca Della Vedova
- Julia Marsal
- Natahn Wiebe Neufeldt
- Natesh Narain
- Antonie Van Mallegem
## Agenda
- Decided to use Rust 1.75 as our minimum version moving forward for logging features and build farm support
- Discussions about ways to test both the rust minimum version and the stable version in our github workflow. Due to some limitations in the github workflow implementation, we currently believe we need to have 2 workflow files that are nearly identical besides the rust-toolchain github action.
  - Both workflows (minimum and stable) will both block CI
  - [Use latest stable Rust CI + Fix Test Errors by mxgrey · Pull Request #420 · ros2-rust/ros2\_rust · GitHub](https://github.com/ros2-rust/ros2_rust/pull/420)
- Grey walked through some changes to the logging PR, mainly added LogParams and a Logger struct.
  - [https://github.com/ros2-rust/ros2\_rust/pull/422](https://github.com/ros2-rust/ros2_rust/pull/422)
- Grey walked through Async execution
  - [Async Execution by mxgrey · Pull Request #421 · ros2-rust/ros2\_rust · GitHub](https://github.com/ros2-rust/ros2_rust/pull/421)
  - Add QoS setting for services
  - Propose implict options for using QoS for services
- Esteve to make a PyPi release for cargo-ament-build
- Julia looking into improved documentation, similar to high level ROS docs
  - [https://docs.ros.org/en/foxy/index.html#](https://docs.ros.org/en/foxy/index.html#)
