# ROS 2 Galactic Default Middleware Announced
**URL:** <https://discourse.openrobotics.org/t/ros-2-galactic-default-middleware-announced/18064>\
**Category:** ROS General\
**Tags:** ros2, dds, wg-middleware, galactic, rmw\
**Created:** [December 17, 2020, 6:29pm UTC](https://discourse.openrobotics.org/t/ros-2-galactic-default-middleware-announced/18064 "2020-12-17T18:29:21Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Katherine\_Scott](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/katherine_scott/32/4434_2.png) [@Katherine\_Scott](https://discourse.openrobotics.org/u/Katherine_Scott)\
**Post date:** [December 17, 2020, 6:29pm UTC](https://discourse.openrobotics.org/t/ros-2-galactic-default-middleware-announced/18064/1 "2020-12-17T18:29:21Z")
</div>
Hi All,
You may recall that one of our main [motivations in designing ROS 2 with a middleware abstraction](https://design.ros2.org/articles/ros_middleware_interface.html) is to provide end users with a flexible transport layer supported by a rich ecosystem of vendors. This competitive approach has already yielded dividends such as the [FastDDS discovery service](http://discourse.ros.org/t/new-discovery-server/17383/2), [IceOryx zero copy memory passing](https://github.com/ros2/design/pull/256), and multiple innovations in [MicroROS for embedded hardware](https://micro-ros.github.io/docs/concepts/middleware/memo_prof/). While some have called this “The DDS Wars” I prefer to think of it as the “DDS [Cambrian Explosion](https://en.wikipedia.org/wiki/Cambrian_explosion)”, as we see [more](http://discourse.ros.org/t/introduction-gurumdds-rmw-gurumnetworks/16866) and [more](http://discourse.ros.org/t/ros2-and-dds-webinar-by-object-computing/14603) vendors of DDS and other [middlewares](https://github.com/esteve/rmw_zenoh) become interested in ROS 2, and how their implementations can bring new features to bear on different parts of the robotics ecosystem.
ROS 2 has long supported multiple middlewares, and will continue to do so. But of course there has to be a default configuration that just works for most users. [As discussed in previous posts](http://discourse.ros.org/t/community-feedback-default-rmw-for-ros-2-galactic/16450), starting with Galactic Geochelone the _default_ RMW configuration for each ROS 2 distro will be selected by the ROS 2 Technical Steering Committee (TSC) after a thorough vetting process. It is worth noting that when we say default, we really do mean default, and users can continue to choose non-default RMW configurations. The TSC aims to choose the best default for each distro, but that doesn’t mean that it will be the best choice for every application. Importantly, changing the RMW configuration on your robot is simply a matter of [running a handful of commands](https://index.ros.org/doc/ros2/Installation/DDS-Implementations/).
I am happy to announce that after careful consideration the ROS 2 TSC has selected [CycloneDDS](https://github.com/eclipse-cyclonedds/cyclonedds) to be the default RMW for ROS 2 Galactic Geochelone. This vote is the result of a thoughtful review and discussion of the available options by the ROS 2 TSC, including a comprehensive technical evaluation of the Tier 1 RMWs by the team at Open Robotics. [That report](https://osrf.github.io/TSC-RMW-Reports/), including [source code](https://github.com/osrf/TSC-RMW-Reports/tree/main/galactic) and [data](https://github.com/osrf/TSC-RMW-Reports/tree/main/galactic/data), is available to all. The report includes [performance statistics](https://osrf.github.io/TSC-RMW-Reports/#BuildFarm) about each RMW implementation, [simulated](https://osrf.github.io/TSC-RMW-Reports/#Mininet) and [real world](https://osrf.github.io/TSC-RMW-Reports/#WiFi) testing of each RMW, a review of the [code quality](https://osrf.github.io/TSC-RMW-Reports/#CodeQuality) and [responsiveness of each RMW vendor](https://osrf.github.io/TSC-RMW-Reports/#GitHubStats), and a community [survey](https://osrf.github.io/TSC-RMW-Reports/#Survey). On balance, the similarities among the Tier 1 RMWs are greater than their differences, and this was a hard decision for the TSC. We hope you make use of the report in selecting your RMW implementation, and feel free to send us your feedback. We intend this report and its future iterations, as well as the tools developed in generating it, to be a neutral source of RMW information for the ROS community.
We’ll start implementing the TSC’s decision soon. We expect the change of the default RMW to CycloneDDS to be merged by late January 2021, and available for testing in [Rolling](https://index.ros.org/doc/ros2/Releases/Release-Rolling-Ridley/) soon after. We realize that this change will impact many users, but we also believe the impacts will be minimal. One important difference is that, whereas Foxy’s default behavior via [FastDDS is asynchronous](https://eprosima.com/index.php/resources-all/performance/dds-asynchronous-vs-synchronous-publishing) publishing (similar to ROS 1), Galactic’s default behavior via CycloneDDS will be synchronous publishing. This will change the behavior of calls to publish on a Publisher when more data is being sent than the network can handle, and perhaps in other cases; we’ll include more details in the near future (you can also read the [report](https://osrf.github.io/TSC-RMW-Reports/)). If you encounter issues related to this or other changes when you update to Galactic, [please report them](https://github.com/ros2/ros2/issues/954)! And remember that, as is the case now with Foxy, you can change your RMW configuration with just a [handful of commands](https://index.ros.org/doc/ros2/Installation/DDS-Implementations/). If you would like to help with this process or would like to beta test the latest ROS 2 release (particularly on a larger multi-robot scenario) please contact me or the core dev team.
**Author:** ![Jaime\_Martin\_Losa](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/jaime_martin_losa/32/4074_2.png) [@Jaime\_Martin\_Losa](https://discourse.openrobotics.org/u/Jaime_Martin_Losa)\
**Post date:** [December 17, 2020, 6:48pm UTC](https://discourse.openrobotics.org/t/ros-2-galactic-default-middleware-announced/18064/2 "2020-12-17T18:48:41Z")
</div>
Hi All,
First of all, on behalf of the team behind Fast DDS, a big thank you to trust our implementation over these 4 years.
I have to add the default is going to be voted for every release, and that gives the opportunity to be tested by the ROS 2 users in every release.
Fast DDS is the default in Foxy, the long term support (LTS) release of ROS 2, and 100% available in the next ROS 2 release as a Tier I RMW implementation, just changing an environment variable.
Asynchronous and Synchronous modes are available in Fast DDS, and you can switch between both modes in both Foxy and the future Galactic.
Our Fast DDS Discovery Server is part of the ROS Docs, and it will be improved for Galactic.
And of course, as the coordinators of Micro-ROS and the team behind XRCE-DDS, you can count on a new release for Galactic.
Same applies to our Integration Service, VisualROS, and the upcoming tools for Lossy networks.
Actually, besides our published roadmap in all our products, we have some new exciting features coming to complete the ROS 2 ecosystem. Just a clue: AI.
