We’ve released an open-source ROS 2 bridge for the Rokoko Device SDK. It takes solved hand data from Smartgloves II and publishes it natively into ROS 2.
What’s included:
- 26-joint hand poses per solved frame, in OpenXR
XrHandJointEXTorder. - TF transforms, one per joint (opt-in).
- RViz visualization of the hand skeleton (opt-in).
- Per-hand diagnostics on
/diagnostics, once a second. - A calibrate service to set which direction is “forward”.
- One launch command starts the driver, hand solver and bridge together.
- One left and one right glove are supported at a time.
Requirements: ROS 2 Lyrical Luth and Rokoko Device SDK 0.10.0 or newer.
Licensed under Apache 2.0.
