Robotiq_description and robotiq_controllers releases moving from ros2_robotiq_gripper to robotiq-ros
Hi all,
The robotiq_controllers and robotiq_description packages on Humble, Jazzy, Lyrical and Rolling will soon be released from robotiq/robotiq-ros instead of PickNikRobotics/ros2_robotiq_gripper, with PickNik’s agreement. robotiq-ros started as a fork of ros2_robotiq_gripper and is maintained by Robotiq. The same release will also add robotiq_driver, robotiq_msgs and the other robotiq-ros packages to the build farm for the first time. Kilted is not affected and stays on PickNik’s 0.0.1 until its end of life.
Because apt upgrades can’t be undone, here is what will change for you.
What stays the same: the package names, the file paths, the robotiq_gripper macro and its arguments, the joint and link names, the robotiq_driver/RobotiqGripperHardwareInterface plugin and the RobotiqActivationController. The 0.0.1 names sim_ignition, sim_isaac, fake_sensor_commands, urdf/robotiq_gripper.ros2_control.xacro and the connected_to argument of ur_to_robotiq still work, but print a deprecation warning. We expanded the released descriptions of Kinova’s ros2_kortex, Clearpath’s clearpath_common and Husarion’s husarion_components_description against the new packages on every distro where they are released, and our CI will continue to check them.
What changes:
  • The version goes from 0.0.1 to 1.x.
  • Installing robotiq_controllers now also installs robotiq_driver and robotiq_msgs.
  • With mock hardware (use_fake_hardware:=true), /joint_states carries only the driven joint, robotiq_85_left_knuckle_joint. robot_state_publisher derives the other finger joints from the URDF’s mimic tags. If your code reads the other finger joints from /joint_states, please tell us.
  • In Gazebo, the plugin is gz_ros2_control/GazeboSimSystem instead of ign_ros2_control/IgnitionSystem. gz_ros2_control registers both names.
  • With sim_isaac, the plugin is topic_based_ros2_control/TopicBasedSystem instead of isaac_ros2_control/IsaacSystem, on the same topics.
  • You also get more state interfaces and more controllers. See the README.
If something breaks: please open an issue on robotiq-ros. Until it’s fixed, you can build 0.0.1 from source (the 0.0.1 tag of ros2_robotiq_gripper), or point apt at the snapshots.ros.org repository from before the sync.
Timeline:
  1. On 2026-11-18, if nobody raises a blocker: we open the rosdistro PRs.
  2. A few days after each merge: the packages reach ros-testing. We’ll post here, so you can try them before they reach the main repository.
  3. At each distro’s next sync: the packages reach the main repository.
Questions and concerns are welcome here.
Thanks, good question. In short, URDFs don’t need to change, whether you come from the 0.0.1 release or from PickNik’s main.
Plugin names: robotiq_driver/RobotiqGripperHardwareInterface and robotiq_controllers/RobotiqActivationController keep their names. With main, the Gazebo (gz_ros2_control/GazeboSimSystem) and Isaac (topic_based_ros2_control/TopicBasedSystem) plugins are also the same as before.
Macros: robotiq_gripper and robotiq_gripper_ros2_control keep their names, and so do the files that define them. They accept the argument names from both 0.0.1 and main, and the older ones print a deprecation warning. Checking this for your question, we found one gap: called directly, robotiq_gripper_ros2_control doesn’t accept main’s isaac_joint_commands and isaac_joint_states yet (nor sim_isaac for the 2F-140). The robotiq_gripper macro already does. robotiq-ros#165 fixes it, and we’ll merge it before the release.
Distros: we test Humble, Jazzy, Lyrical and Rolling in CI. Kilted keeps PickNik’s 0.0.1 binaries until its end of life this month, but building robotiq-ros from source works there too: we built it and ran its tests on Kilted today.
Switching .repos: replace the ros2_robotiq_gripper entry with https://github.com/robotiq/robotiq-ros and run rosdep install as usual. The repository holds more than the gripper, so colcon build --packages-up-to robotiq_controllers robotiq_description builds only what you need.
