Robot Brain: a memory runtime for task experience, with a ROS 2 reference bridge (public alpha, closed core)
I’m the developer of Robot Brain. I’m posting in Projects because it ships with a ROS 2 reference bridge and I want feedback from people who would actually wire it in. Up front: the core is not open source. It ships as a compiled package under an evaluation license; the repo holds docs, examples and the issue tracker.
What it does
It keeps task experience (an episode, where it failed, what a human did, what followed) with the source of every fact, and returns what is relevant when a later task asks under its current conditions. With a model key it drafts candidate lessons from that experience, which you review before they are used. New outcomes and counterexamples revise those lessons.
Interfaces
Local HTTP API on loopback:
  • POST /v1/robots register a robot instance
  • POST /v1/events:batch episodes and events (default cap 50 events / 1 MiB per batch)
  • POST /v1/recall original source facts
  • POST /v1/memory/recall reviewed task memory
  • POST /v1/feedback whether the result was used, and what happened
  • POST /v1/events/{event_id}/revoke withdraw a source event
Python SDK over the same calls (register_robot, ingest, recall, recall_memory, feedback). No NumPy dependency, so serialization is explicit. ExperienceJournal keeps the full episode locally, including delivery position, action intents and use feedback. If delivery fails, you reopen the journal and flush it explicitly.
ROS 2 reference bridge: task-level DDS services, a persistent request queue and source-bound private configuration. Queue acceptance and host confirmation are separate steps. Exercised on Ubuntu 24.04 / Jazzy / ARM64 with real ROS processes. Simulation clock values keep their own domain; it does not invent UTC timestamps without a valid mapping. The bridge guide ships inside the install package.
Gymnasium helper for ordinary single environments: reset info, seed, transitions, rewards and terminated vs truncated are preserved. VectorEnv, AutoReset and asynchronous multi-agent are not implemented.
Why the feedback call exists: recall alone tells you nothing. Recording whether the planner used what came back, and what followed, is how you check whether memory changed behavior.
Boundaries
  • Perception, control, policy, execution permissions and e-stop stay with the integrator. It does not trigger motor actions.
  • Missing memory or an unavailable service needs an application-defined fallback.
  • No weight training. What gets revised is experience content and the conditions it applies under.
  • JSON assets are capped at 2 MiB each. Images and video need your own asset manager; this interface does not do visual understanding.
  • Model-assisted steps use your own Gemini key, called directly against Google and billed to you. Selected material goes to the model provider only with your explicit authorization. Install, experience write and source-fact recall work without a key.
Try it without hardware
examples/README.md in the repo has a synthetic Python example that registers a synthetic robot, ingests a short episode and recalls source facts. No model key, no control hardware.
Platforms: Apple Silicon Mac (CPython 3.12); Linux ARM64 and AMD64 via OCI, with containerd/nerdctl as the tested path. ARM64 validated in an ARM VM; AMD64 so far under Rosetta translation, not yet on a physical AMD64 host. The local console is mostly Chinese for now; API, SDK and docs are English. Evaluation is free under the bundled license; model costs are separate.
Site: Monolithos Robot Brain — Every task ends. Experience carries on.
Repo: GitHub - silas-zhen/robot-brain: Persistent memory for embodied AI. Source-backed experience for robot planning, recovery and training review. · GitHub
Bring one real task boundary: a failure, a human correction, or the moment before the next plan. Run experience write and recall first, then decide where memory should take part in the decision. We want to build the experience interface and the ways experience gets used together with embodied AI teams.
Integration guide: docs/en/integration.md in the repo.
Tell us your task: the integration request template under the repo’s Issues.
For those running ROS 2 on hardware or in long sim campaigns: where would you call recall? Before the planner, inside a recovery behavior tree, or only in offline review? And which of the bridge’s assumptions would break first on your setup?
