QERRA-v2 Demo 5: Closed-Loop Moral Gating, Physical Safety, and Values Selection (TIAGo in Webots)
Hi there !
Yes that’s right and thank you for this observation. Even if i do not see that as an embarassment but mostly as a process and hopefully i can add some real value :blush: , that would be great as well.
Infact these kind of issues have been created many exhaustion combined with my self-taught character.I’m learning & applying all these while i’m building the Engine. I’m not an academic or a classical trained engineer.
On simple, routine commands (like “Take this cart to the assembly line” or “Fetch the folder” in my earlier demos), when no red flags are raised, the engine gives a baseline score of 0.25 (Safe) and lets the robot drive. On the ~80 test cases I’ve built so far, harmless instructions pass through without issues.
In an earlier version, if a sentence said “I do NOT want to hurt myself”, the semantic model latched onto “hurt myself” and triggered a full critical emergency stop. I had to learn the hard way how to put a direct regex check in front of the model to catch the negation and stop it from crying wolf.
Another time, I tried expanding my vector descriptions to make them smarter, but it ended up diluting the embeddings so badly that it started failing basic sentences.
My testing so far is a small batch of sentences which i’m trying to approach through the real-world lens, yet there are not 100% real commands from people working on an actual floor. So I definitely can’t say it’s tested for the real world yet.
How do you usually test yours against normal, everyday tasks? Do you pull from real logs or use a specific dataset? If you want to add something please do
Thanks again
