Preparing for Humble sync and patch release 2026-09-14
We’re planning for a Humble :humble: sync and patch release on 2026-09-14T07:00:00Z.
There are currently 319 regressions* and 666 packages to release.
We will start holding rosdistro PRs for the sync today (2026-09-08T07:00:00Z) and will plan to do the sync and patch on 2026-09-14T07:00:00Z.
(*) the number of regressions should go down soon, and I’m working to identify and help fix some more.
The patch and sync are out!
In this sync, I’m having issue of downloading mavros package from the apt repository.
@christophebedard
Also lot of packages were not found, please consider this as high priority issue, this kind of carelessness is causing lot of issues in our CI build. I’m highly escalating this. Please fix asap.
The mavros package was removed from the distribution in this sync because the binary package was failing to build for over a month now. This is a package that is not under the management of the ROS PMC, and needs to be reported upstream to get fixed, which it appears it already has: 2.15.1 Humble binaries missing: mavros, mavros_extras and libmavconn unpublished for jammy (mavros_msgs published) · Issue #2293 · mavlink/mavros
mavros package status Hbin_uJ64__mavros__ubuntu_jammy_amd64__binary - Jenkins
The libmavconn package, a dependency is what is blocking it: Hbin_uJ64__libmavconn__ubuntu_jammy_amd64__binary - Jenkins
The error:
02:15:47 CMake Error at CMakeLists.txt:117 (find_package):
02:15:47   By not providing "Findament_cmake_google_benchmark.cmake" in
02:15:47   CMAKE_MODULE_PATH this project has asked CMake to find a package
02:15:47   configuration file provided by "ament_cmake_google_benchmark", but CMake
02:15:47   did not find one.
02:15:47
02:15:47   Could not find a package configuration file provided by
02:15:47   "ament_cmake_google_benchmark" with any of the following names:
02:15:47
02:15:47     ament_cmake_google_benchmarkConfig.cmake
02:15:47     ament_cmake_google_benchmark-config.cmake
02:15:47
02:15:47   Add the installation prefix of "ament_cmake_google_benchmark" to
02:15:47   CMAKE_PREFIX_PATH or set "ament_cmake_google_benchmark_DIR" to a directory
02:15:47   containing one of the above files.  If "ament_cmake_google_benchmark"
02:15:47   provides a separate development package or SDK, be sure it has been
02:15:47   installed.
02:15:47
02:15:47
02:15:47 -- Configuring incomplete, errors occurred!
Only 11 packages were removed in this sync:
Removed Packages [11]:
Instead of removing the package, why can’t we have older stable versions of it. Removing is failing to detect the modules for apt install.
There is no guarantee that a previous version of the package will work with current dependency versions, so it must be rebuilt successfully or removed.
Regarding MAVROS, the libmavconn package was failing to build on the buildfarm. I submitted a fix for it and then asked the maintainer to create a new release to fix the regression to avoid this situation, but I was told they weren’t ready for a new release.
As @mjcarroll said, this is something you should talk to the MAVROS maintainers about. Reverting to a previous version is tricky, because it may not build against newer versions of upstream packages, and may lead to regressions for downstream packages.
Once the MAVROS maintainers make a new release (and it’s bloomed and merged into rosdistro), it will be eventually available from the testing apt repository after it gets successfully built by the buildfarm.
