Preparing for Eloquent Sync and Patch Release 2020-04-17
It’s time for another Eloquent sync and patch release.
We’re using a GitHub project board to track the release status.
If there is a pull request that you want included in the patch release you can propose it on the release tracking issue .
There are also a good number of new packages from the community ready for sync:
If you find a regression when testing, please report it upstream and leave a comment here so we can track it leading up to the sync.
Please get your releases in for this sync as early as you can, and on 2019-04-14 we’ll hold all rosdistro PRs unless they fix reported regressions.
Some of the Windows buildfarm settings for foxy deveclopment ended up conflicting with what eloquent needed for release. Due to this, I have ended up doing a sync to get the deb packages out.
A full patch release will come after the foxy release, and I will continue to use the same project board until then.
Sync announcement: New packages for Eloquent Elusor 2020-05-29 - ROS General - Open Robotics Discourse
