[Open Source] DDS AutoDiag v0.1.0 — ROS 2 DDS Diagnostics with AI-Assisted Troubleshooting
Hi ROS community! :waving_hand:
Ever had two ROS 2 systems that could ping each other, use the same ROS_DOMAIN_ID, but still couldn’t discover each other’s topics?
I’ve encountered similar issues while working with distributed ROS 2 systems. Troubleshooting often means manually investigating DDS discovery, middleware configurations, QoS policies, and container networking.
To make this process more systematic, I developed DDS AutoDiag v0.1.0, an independent, MIT-licensed open-source tool for diagnosing ROS 2 communication problems across robots, computers, and containers.
What does it offer?
:magnifying_glass_tilted_left: 23 diagnostic checks
Investigates common ROS 2 communication issues, including DDS discovery, network configuration, middleware settings, and QoS compatibility.
:bar_chart: Visual diagnostics
Provides a graphical interface to explore diagnostic results and identify potentially broken communication paths.
:robot: AI-assisted troubleshooting
Explains diagnostic findings, suggests configuration changes, and references curated ROS 2 documentation to help developers understand the underlying issues.
:sparkles: AI-powered RViz integration
Allows developers to configure supported RViz visualizations through natural-language instructions.
See it in action
:movie_camera: https://youtu.be/OwRHfeO_ueo
Try DDS AutoDiag:
GitHub: GitHub - Animesh2507/dds-autodiag: Tells you why your ROS 2 nodes can't talk to each other, and fixes your RViz view for you. Read-only DDS diagnostics + AI. · GitHub
Documentation: DDS AutoDiag - DDS AutoDiag
Looking for community feedback
This is the first public release, and I’d love to hear from developers working with distributed ROS 2 environments.
I’m particularly interested in feedback on diagnostic accuracy, missing failure scenarios, and improvements to the troubleshooting workflow.
If you encounter issues or have suggestions, feel free to open a GitHub issue or contribute!
How do you currently troubleshoot DDS communication failures across multiple ROS 2 systems?
Thanks for taking a look!
Regards,
Animesh Gunaki
