# New way of installing ROS
**URL:** https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929
**Category:** ROS General
**Created:** [October 5, 2023, 9:03am UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929 "2023-10-05T09:03:36Z")
**Posts on this page:** 9
**Page:** 1
<div class="post-metadata">
### Author: ![ruben-arts](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/ruben-arts/32/18529_2.png) [@ruben-arts](https://discourse.openrobotics.org/u/ruben-arts)
#### Post date: [October 5, 2023, 9:03am UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/1 "2023-10-05T09:03:36Z")
</div>
Here is a blog about a new way of installing ROS.
> **[prefix.dev – solving software package management](https://prefix.dev/blog/pixi_ros)**
> The software package management platform for Python, C++, R, Rust and more
We’re heavily developing a tool called `pixi` that will change the way you can make virtual environments using the conda ecosystem.
No more `apt`, `pip`, `brew`, `nuget`, just one tool that is shared over all platforms (Windows, MacOS and Linux).
Do you want multiple versions of ROS on your computer without them breaking each other installation? And not just ROS1 and ROS2 but even different versions of the same ROS. Then you should definitely give it a try.
Don’t go through the pain of developing in a Docker container.
I hope this might help some of you!
### Author: ![peci1](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/peci1/32/10145_2.png) [@peci1](https://discourse.openrobotics.org/u/peci1)
#### Post date: [October 5, 2023, 11:56am UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/2 "2023-10-05T11:56:39Z")
</div>
This looks quite nice. However, RoboStack has a quite limited subset of the released ROS packages. Does pixi somehow improve on this?
Also, does it run on conda-forge? I was always a bit concerned of putting all the development effort on servers run by a private commercial company (Anaconda). What if they decide they’ll stop funding conda-forge servers?
#### Post date: [October 5, 2023, 2:03pm UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/3 "2023-10-05T14:03:38Z")
</div>
Great questions!
Robostack should be growing in the close future. We have interest from large companies like the MoveIt maintainers. We would really like to see more contributes to add more packages. Often its as easy as adding it to the [vinca yaml](https://github.com/RoboStack/ros-humble). This is something we’re very eager to help with. As it is community run, it simply needs more users and contributes to become even greater.
Pixi itself will not extend this list but the user experience will hopefully start to pull in more users into the conda, thus RoboStack, eco-system.
By default pixi runs from the `conda-forge `channel but is able to use any channel, private or public. Next to that the data of `conda-forge` is also stored on [GitHub](https://github.com/orgs/channel-mirrors/packages) and the bots are completely open source. So if Anaconda would fail to continue supporting conda-forge it would be relatively easy to let another company take over the work. We (prefix.dev) are for that fact also running our own mirror as it is not that hard to backup.
Our company’s mission is to improve the package management with the use of the conda ecosystem. We got public funding to do these improvements.
Right now we’re mainly looking for users that want to use pixi and give constructive feedback on how to improve it. But the experience we had at our previous company really makes us believe this is the direction that is going to help the ROS community immensely.
#### Post date: [October 5, 2023, 2:27pm UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/4 "2023-10-05T14:27:05Z")
</div>
> [@ruben-arts](#):
Thanks for the clarification. So there’s no plan to “mirror” whatever gets into rosdistro? I know not all dependencies are packaged, but what about “building the subset of rosdistro that has all dependencies packaged”?
#### Post date: [October 5, 2023, 3:29pm UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/5 "2023-10-05T15:29:38Z")
</div>
Our ultimate goal is that OSRF would publish to the RoboStack channel directly.
As of right now it is not possible to simply mirror as there are to many manual steps, and especially the osx and windows version often need patches.
#### Post date: [October 5, 2023, 5:59pm UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/6 "2023-10-05T17:59:21Z")
</div>
> [@ruben-arts](#):
Have you already talked to them about this? 🙂
#### Post date: [October 6, 2023, 1:15pm UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/7 "2023-10-06T13:15:05Z")
</div>
There have been conversations with some of the main maintainers of ROS. But there are no direct commitments as of right now. It would be great if this conversation sparks some more conversations 😃
@wolfv @traversaro @Tobias_Fischer are the main maintainers of RoboStack so maybe they can share some more light on this.
### Author: ![wolfv](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/wolfv/32/2863_2.png) [@wolfv](https://discourse.openrobotics.org/u/wolfv)
#### Post date: [October 6, 2023, 2:41pm UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/8 "2023-10-06T14:41:12Z")
</div>
Yeah we’ve consistently had conversations at the past ROSCONs with OSRF. Packaging is a hard topic and it takes a lot of time and effort. I think with the RoboStack project we’re demonstrating that there is an interesting opportunity! We’ve definitely seen growing interest.
At prefix we’re also committed to improve the tooling around creating these packages: rattler-build is a new tool that is written from the ground up in Rust that builds conda-packages in high-speed. This should help ease the maintenance of RoboStack in the future … we will get there!
### Author: ![system](https://us1.discourse-cdn.com/flex022/uploads/ros/original/3X/b/6/b607ee3cc8e908b1b613bd74a683d749fea635a1.svg) [@system](https://discourse.openrobotics.org/u/system)
#### Post date: [November 5, 2023, 2:41pm UTC](https://discourse.openrobotics.org/t/new-way-of-installing-ros/33929/9 "2023-11-05T14:41:14Z")
</div>
