Weβre happy to announce 6 new packages and 58 updates are now available in ROS Noetic. This sync was tagged as noetic/2021-09-27.
Besides the normal package updates, this update also includes a fix for CVE-2021-37146 in ros_comm. In versions of ros_comm up to and including version 1.15.11, a malformed XMLRPC request would cause roscore to spend an excessive amount of time processing the request, leading to a potential denial-of-service with repeated requests. A fix to make the XMLRPC server in roscore reject malformed requests was merged in PR https://github.com/ros/ros_comm/pull/2185, and released in ros_comm version 1.15.13 (part of this sync). We rate the impact of this vulnerability as low; an attacker with access to roscore could do various other things to cause a denial-of-service attack or worse. To our knowledge this vulnerability was never seen in the wild. This issue was initially reported by Junfeng Yang from Didi Research America, LLC.
Added Packages [6]:
- ros-noetic-clober-msgs: 1.0.1-1
- ros-noetic-microstrain-inertial-examples: 2.0.4-1
- ros-noetic-qb-chain-control: 2.2.2-1
- ros-noetic-qb-chain-description: 2.2.2-1
- ros-noetic-qb-move-control: 2.2.2-1
- ros-noetic-qb-move-description: 2.2.2-1
Updated Packages [58]:
- ros-noetic-apriltag: 3.1.5-1 β 3.1.6-1
- ros-noetic-audio-capture: 0.3.11-1 β 0.3.12-1
- ros-noetic-audio-common: 0.3.11-1 β 0.3.12-1
- ros-noetic-audio-common-msgs: 0.3.11-1 β 0.3.12-1
- ros-noetic-audio-play: 0.3.11-1 β 0.3.12-1
- ros-noetic-bosch-locator-bridge: 1.0.2-1 β 1.0.3-1
- ros-noetic-computer-status-msgs: 2.0.0-2 β 2.1.0-1
- ros-noetic-eigenpy: 2.6.7-1 β 2.6.8-1
- ros-noetic-franka-control: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-description: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-example-controllers: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-gazebo: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-gripper: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-hw: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-msgs: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-ros: 0.8.0-1 β 0.8.1-1
- ros-noetic-franka-visualization: 0.8.0-1 β 0.8.1-1
- ros-noetic-libmavconn: 1.8.0-1 β 1.9.0-1
- ros-noetic-mavlink: 2021.8.8-1 β 2021.9.9-1
- ros-noetic-mavros: 1.8.0-1 β 1.9.0-1
- ros-noetic-mavros-extras: 1.8.0-1 β 1.9.0-1
- ros-noetic-mavros-msgs: 1.8.0-1 β 1.9.0-1
- ros-noetic-message-filters: 1.15.11-1 β 1.15.13-1
- ros-noetic-microstrain-inertial-driver: 2.0.2-1 β 2.0.4-1
- ros-noetic-microstrain-inertial-msgs: 2.0.2-1 β 2.0.4-1
- ros-noetic-pcl-conversions: 1.7.2-1 β 1.7.3-1
- ros-noetic-pcl-ros: 1.7.2-1 β 1.7.3-1
- ros-noetic-perception-pcl: 1.7.2-1 β 1.7.3-1
- ros-noetic-plotjuggler: 3.2.1-1 β 3.3.0-1
- ros-noetic-psen-scan-v2: 0.3.1-1 β 0.3.2-1
- ros-noetic-ros-comm: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosbag: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosbag-storage: 1.15.11-1 β 1.15.13-1
- ros-noetic-roscpp: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosgraph: 1.15.11-1 β 1.15.13-1
- ros-noetic-roslaunch: 1.15.11-1 β 1.15.13-1
- ros-noetic-roslz4: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosmaster: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosmsg: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosnode: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosout: 1.15.11-1 β 1.15.13-1
- ros-noetic-rosparam: 1.15.11-1 β 1.15.13-1
- ros-noetic-rospy: 1.15.11-1 β 1.15.13-1
- ros-noetic-rospy-message-converter: 0.5.6-1 β 0.5.7-1
- ros-noetic-rosservice: 1.15.11-1 β 1.15.13-1
- ros-noetic-rostest: 1.15.11-1 β 1.15.13-1
- ros-noetic-rostopic: 1.15.11-1 β 1.15.13-1
- ros-noetic-roswtf: 1.15.11-1 β 1.15.13-1
- ros-noetic-slam-toolbox: 1.5.5-1 β 1.5.6-1
- ros-noetic-slam-toolbox-msgs: 1.5.5-1 β 1.5.6-1
- ros-noetic-slam-toolbox-rviz: 1.5.5-1 β 1.5.6-1
- ros-noetic-sound-play: 0.3.11-1 β 0.3.12-1
- ros-noetic-sr-hand-detector: 0.0.6-1 β 0.0.7-1
- ros-noetic-test-mavros: 1.8.0-1 β 1.9.0-1
- ros-noetic-topic-tools: 1.15.11-1 β 1.15.13-1
- ros-noetic-ur-client-library: 0.3.1-1 β 0.3.2-1
- ros-noetic-xacro: 1.14.8-1 β 1.14.9-1
- ros-noetic-xmlrpcpp: 1.15.11-1 β 1.15.13-1
Removed Packages [0]:
- Alessandro Tondo
- Alexander Gutenkunst
- Austin Hendrix
- Davide Faconti
- Felix Exner
- Franka Emika GmbH
- Isaac I.Y. Saito
- Jacob Perron
- Justin Carpentier
- Martin GΓΌnther
- Max Krogius
- Paul Bovbel
- Rob Fisher
- Robert Haschke
- Shadow Robotβs Software Team
- Stefan Laible
- Steve Macenski
- Vladimir Ermakov
- clobot-git
