We’re happy to announce an update of 47 packages for Kinetic Kame for the first release in 2021.
Thank you to everyone who helped make these updates possible!
Full details are below.
Package Updates for kinetic
Added Packages [0]:
Updated Packages [47]:
- ros-kinetic-amcl: 1.14.8-1 → 1.14.9-1
- ros-kinetic-audio-capture: 0.3.9-1 → 0.3.10-1
- ros-kinetic-audio-common: 0.3.9-1 → 0.3.10-1
- ros-kinetic-audio-common-msgs: 0.3.9-1 → 0.3.10-1
- ros-kinetic-audio-play: 0.3.9-1 → 0.3.10-1
- ros-kinetic-axis-camera: 0.3.0-0 → 0.3.1-1
- ros-kinetic-base-local-planner: 1.14.8-1 → 1.14.9-1
- ros-kinetic-carrot-planner: 1.14.8-1 → 1.14.9-1
- ros-kinetic-clear-costmap-recovery: 1.14.8-1 → 1.14.9-1
- ros-kinetic-costmap-2d: 1.14.8-1 → 1.14.9-1
- ros-kinetic-costmap-cspace: 0.10.4-1 → 0.10.5-1
- ros-kinetic-dwa-local-planner: 1.14.8-1 → 1.14.9-1
- ros-kinetic-fake-localization: 1.14.8-1 → 1.14.9-1
- ros-kinetic-global-planner: 1.14.8-1 → 1.14.9-1
- ros-kinetic-joystick-interrupt: 0.10.4-1 → 0.10.5-1
- ros-kinetic-libmavconn: 1.5.0-1 → 1.5.1-1
- ros-kinetic-librealsense2: 2.40.0-1 → 2.41.0-1
- ros-kinetic-map-organizer: 0.10.4-1 → 0.10.5-1
- ros-kinetic-map-server: 1.14.8-1 → 1.14.9-1
- ros-kinetic-mavlink: 2020.12.12-1 → 2021.1.4-1
- ros-kinetic-mavros: 1.5.0-1 → 1.5.1-1
- ros-kinetic-mavros-extras: 1.5.0-1 → 1.5.1-1
- ros-kinetic-mavros-msgs: 1.5.0-1 → 1.5.1-1
- ros-kinetic-move-base: 1.14.8-1 → 1.14.9-1
- ros-kinetic-move-slow-and-clear: 1.14.8-1 → 1.14.9-1
- ros-kinetic-moveit-python: 0.3.4-1 → 0.3.5-1
- ros-kinetic-nav-core: 1.14.8-1 → 1.14.9-1
- ros-kinetic-navfn: 1.14.8-1 → 1.14.9-1
- ros-kinetic-navigation: 1.14.8-1 → 1.14.9-1
- ros-kinetic-neonavigation: 0.10.4-1 → 0.10.5-1
- ros-kinetic-neonavigation-common: 0.10.4-1 → 0.10.5-1
- ros-kinetic-neonavigation-launch: 0.10.4-1 → 0.10.5-1
- ros-kinetic-novatel-oem7-driver: 1.1.0-1 → 2.0.0-1
- ros-kinetic-novatel-oem7-msgs: 1.1.0-1 → 2.0.0-1
- ros-kinetic-obj-to-pointcloud: 0.10.4-1 → 0.10.5-1
- ros-kinetic-planner-cspace: 0.10.4-1 → 0.10.5-1
- ros-kinetic-realsense2-camera: 2.2.20-1 → 2.2.21-1
- ros-kinetic-realsense2-description: 2.2.20-1 → 2.2.21-1
- ros-kinetic-robot-pose-ekf: 1.14.8-1 → 1.14.9-1
- ros-kinetic-rotate-recovery: 1.14.8-1 → 1.14.9-1
- ros-kinetic-safety-limiter: 0.10.4-1 → 0.10.5-1
- ros-kinetic-sound-play: 0.3.9-1 → 0.3.10-1
- ros-kinetic-test-mavros: 1.5.0-1 → 1.5.1-1
- ros-kinetic-track-odometry: 0.10.4-1 → 0.10.5-1
- ros-kinetic-trajectory-tracker: 0.10.4-1 → 0.10.5-1
- ros-kinetic-voxel-grid: 1.14.8-1 → 1.14.9-1
- ros-kinetic-ypspur-ros: 0.3.1-1 → 0.3.4-1
Removed Packages [0]:
- Atsushi Watanabe
- Austin Hendrix
- Chris Iverach-Brereton
- David V. Lu!!
- Michael Ferguson
- NovAtel Support
- Sergey Dorodnicov
- Vladimir Ermakov
