# New Ignition releases 2022-03-25 (Fortress, Edifice, Citadel)
**URL:** <https://discourse.openrobotics.org/t/new-ignition-releases-2022-03-25-fortress-edifice-citadel/49089>\
**Category:** Gazebo Announcements and News\
**Tags:** release, ignition, edifice, fortress, citadel\
**Created:** [March 25, 2022, 10:28pm UTC](https://discourse.openrobotics.org/t/new-ignition-releases-2022-03-25-fortress-edifice-citadel/49089 "2022-03-25T22:28:57Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![chapulina\_gazebo](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/chapulina_gazebo/32/1637_2.png) [@chapulina\_gazebo](https://discourse.openrobotics.org/u/chapulina_gazebo)\
**Post date:** [March 25, 2022, 10:28pm UTC](https://discourse.openrobotics.org/t/new-ignition-releases-2022-03-25-fortress-edifice-citadel/49089/1 "2022-03-25T22:28:57Z")
</div>
# Highlights
- Python APIs for Gazebo, see:
[https://community.gazebosim.org/t/ignition-python-wrappers-released-in-fortress/1332](https://community.gazebosim.org/t/ignition-python-wrappers-released-in-fortress/1332)
- Various libraries are getting their final Edifice releases, see:
[https://community.gazebosim.org/t/edifice-approaching-end-of-life/1328](https://community.gazebosim.org/t/edifice-approaching-end-of-life/1328)
- Echo Ignition Transport messages in JSON for easier processing
- The shader parameters system now supports shader languages other than GLSL, such as Metal
- Easily manipulate messages with the new `ignition::msgs::PointCloudPackedIterator`
# Releases
These are the minor and patch releases that came out since the [previous post](https://community.gazebosim.org/t/new-ignition-releases-2022-03-01-citadel-edifice-fortress/1313).
## Ignition Gazebo 6.7.0 (Fortress)
### Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-gazebo/blob/ign-gazebo6/Changelog.md)
1. Added Python interfaces to some Ignition Gazebo methods
  - [Pull request #1219](https://github.com/ignitionrobotics/ign-gazebo/pull/1219)
2. Use pose multiplication instead of addition
  - [Pull request #1369](https://github.com/ignitionrobotics/ign-gazebo/pull/1369)
3. Disables Failing Buoyancy Tests on Win32
  - [Pull request #1368](https://github.com/ignitionrobotics/ign-gazebo/pull/1368)
4. Extend ShaderParam system to support loading different shader languages
  - [Pull request #1335](https://github.com/ignitionrobotics/ign-gazebo/pull/1335)
5. Populate names of colliding entities in contact points message
  - [Pull request #1351](https://github.com/ignitionrobotics/ign-gazebo/pull/1351)
6. Refactor System functionality into SystemManager
  - [Pull request #1340](https://github.com/ignitionrobotics/ign-gazebo/pull/1340)
7. GzSceneManager: Prevent crash boom when inserted from menu
  - [Pull request #1371](https://github.com/ignitionrobotics/ign-gazebo/pull/1371)
### Contributors
_Aditya Pande_
_Alejandro Hernández Cordero_
_Arjo Chakravarty_
_Ian Chen_
_Jose Luis Rivero_
_Louise Poubel_
_Michael Carroll_
_Steve Peters_
## Ignition Messages 8.3.0 (Fortress)
### Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-msgs/blob/ign-msgs8/Changelog.md)
1. Focal CI: static checkers and doxygen linters
  - [Pull request #230](https://github.com/ignitionrobotics/ign-msgs/pull/230)
2. Pose, twist and odometry with covariance msgs
  - [Pull request #224](https://github.com/ignitionrobotics/ign-msgs/pull/224)
3. Add wheel slip message definition
  - [Pull request #205](https://github.com/ignitionrobotics/ign-msgs/pull/205)
  - [Pull request #227](https://github.com/ignitionrobotics/ign-msgs/pull/227)
4. Add Ubuntu Jammy CI
  - [Pull request #225](https://github.com/ignitionrobotics/ign-msgs/pull/225)
5. Add `PointCloudPacked` iterators
  - [Pull request #210](https://github.com/ignitionrobotics/ign-msgs/pull/210)
  - [Pull request #218](https://github.com/ignitionrobotics/ign-msgs/pull/218)
6. Document pose + spherical coordinates combination on spawn
  - [Pull request #212](https://github.com/ignitionrobotics/ign-msgs/pull/212)
### Contributors
_Aditya Pande_
_Ivan Santiago Paunovic_
_Louise Poubel_
_Steve Peters_
_TyHowellWork_
## Ignition Launch 5.1.0 (Fortress)
### Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-lauinch/blob/ign-launch5/Changelog.md)
1. Use exec instead of `popen` to run `ign-launch` binary
  - [Pull request #151](https://github.com/ignitionrobotics/ign-launch/pull/151)
2. Expose `headless_rendering` SDF tag
  - [Pull request #148](https://github.com/ignitionrobotics/ign-launch/pull/148)
3. Remove spammy CMake message
  - [Pull request #142](https://github.com/ignitionrobotics/ign-launch/pull/142)
### Contributors
_Addisu Z. Taddese_
_Aditya Pande_
_Louise Poubel_
_Nate Koenig_
## Ignition Mesages 5.9.0 (Citadel)
### Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-msgs/blob/ign-msgs5/Changelog.md)
1. Backport NavSat message for ROS bridge compatibility
  - [Pull request #231](https://github.com/ignitionrobotics/ign-msgs/pull/231)
2. Focal CI: static checkers and doxygen linters
3. Add `PointCloudPacked` iterators
### Contributors
_Louise Poubel_
_TyHowellWork_
## SDFormat 11.4.0 and 11.4.1 (🏁 final Edifice release)
## Changelog
[Full changelog](https://github.com/ignitionrobotics/sdformat/blob/sdf11/Changelog.md)
1. Install sdf/1.8 to versioned path
  - [Pull request #890](https://github.com/ignitionrobotics/sdformat/pull/890)
2. Added option to visualize light on the GUI
  - [Pull request #877](https://github.com/ignitionrobotics/sdformat/pull/877)
3. Fix joint parent/child frame existence checks to include interface elements
  - [Pull request #855](https://github.com/ignitionrobotics/sdformat/pull/855)
4. Added to light whether it is on or off
  - [Pull request #851](https://github.com/ignitionrobotics/sdformat/pull/851)
5. Allow model frames (` __model__ `) to be used as joint parent or child
  - [Pull request #833](https://github.com/ignitionrobotics/sdformat/pull/833)
6. Add `ParserConfig` flag for `preserveFixedJoint`
  - [Pull request #815](https://github.com/ignitionrobotics/sdformat/pull/815)
7. Fix compiler warnings
  - [Pull request #808](https://github.com/ignitionrobotics/sdformat/pull/808)
8. `sdf_custom`: fix nested model expectations
  - [Pull request #807](https://github.com/ignitionrobotics/sdformat/pull/807)
9. Fix test compilation with `USE_INTERNAL_URDF`
  - [Pull request #800](https://github.com/ignitionrobotics/sdformat/pull/800)
10. Replace custom CMake code with `ign-cmake2`
  - [Pull request #780](https://github.com/ignitionrobotics/sdformat/pull/780)
11. Fix loading nested include with custom attributes
  - [Pull request #789](https://github.com/ignitionrobotics/sdformat/pull/789)
12. Documentation
  1. Clarify behavior of `//model/model/static`
    - [Pull request #713](https://github.com/ignitionrobotics/sdformat/pull/713)
  2. Only allow one `canonical_link` attribute for model
    - [Pull request #716](https://github.com/ignitionrobotics/sdformat/pull/716)
  3. Don’t mention elements that can’t be included
    - [Pull request #715](https://github.com/ignitionrobotics/sdformat/pull/715)
  4. Clarify documentation on `//pose/@relative_to` in the spec
    - [Pull request #666](https://github.com/ignitionrobotics/sdformat/pull/666)
  5. Remove duplicate link documentation
    - [Pull request #702](https://github.com/ignitionrobotics/sdformat/pull/702)
13. Fix URDF fixed joint reduction of plugins
  - [Pull request #745](https://github.com/ignitionrobotics/sdformat/pull/745)
14. Add `enable_orientation` to 1.6 spec
  - [Pull request #686](https://github.com/ignitionrobotics/sdformat/pull/686)
15. Remove outdated deprecation note from `parser_urdf.hh`
  - [Pull request #740](https://github.com/ignitionrobotics/sdformat/pull/740)
16. Add Joint DOM API to access joint sensors
  - [Pull request #517](https://github.com/ignitionrobotics/sdformat/pull/517)
17. Add force torque sensor
  - [Pull request #393](https://github.com/ignitionrobotics/sdformat/pull/393)
  - [Pull request #669](https://github.com/ignitionrobotics/sdformat/pull/669)
18. Check joint parent link names in `Model::Load`
  - [Pull request #726](https://github.com/ignitionrobotics/sdformat/pull/726)
19. Check joint parent/child names in `Root::Load`
  - [Pull request #727](https://github.com/ignitionrobotics/sdformat/pull/727)
20. Remove empty `//inertial/pose/@relative_to` during 1\_7-\>1.8 conversion
  - [Pull request #720](https://github.com/ignitionrobotics/sdformat/pull/720)
21. Fix `xyz` and `rpy` offsets in fixed joint reduction
  - [Pull request #500](https://github.com/ignitionrobotics/sdformat/pull/500)
22. Infrastructure updates
  - [Pull request #674](https://github.com/ignitionrobotics/sdformat/pull/674)
  - [Pull request #650](https://github.com/ignitionrobotics/sdformat/pull/650)
  - [Pull request #626](https://github.com/ignitionrobotics/sdformat/pull/626)
  - [Pull request #258](https://github.com/ignitionrobotics/sdformat/pull/258)
  - [Pull request #237](https://github.com/ignitionrobotics/sdformat/pull/237)
  - [Pull request #730](https://github.com/ignitionrobotics/sdformat/pull/730)
23. Translate poses of nested models inside other nested models
  - [Pull request #596](https://github.com/ignitionrobotics/sdformat/pull/596)
24. Fix flattening logic for nested model names
  - [Pull request #597](https://github.com/ignitionrobotics/sdformat/pull/597)
25. Parse `rpyOffset` as radians
  - [Pull request #497](https://github.com/ignitionrobotics/sdformat/pull/497)
## Contributors
_Addisu Z. Taddese_
_Ashton Larkin_
_Carlos Agüero_
_Devansh Chawla_
_Ian Chen_
_Jenn Nguyen_
_Jose Luis Rivero_
_Louise Poubel_
_Nate Koenig_
_Nick Lamprianidis_
_Sebastian Wallkötter_
_Steve Peters_
_Varun Agrawal_
## Ignition Msgs 7.3.0 (🏁 final Edifice release)
## Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-msgs/blob/ign-msgs7/Changelog.md)
1. Backport NavSat message for bridge compatibility
4. Add `PointCloudPacked` iterators
5. Fix trivial typo in command line help message
  - [Pull request #191](https://github.com/ignitionrobotics/ign-msgs/pull/191)
6. Support colcon in windows CI
  - [Pull request #189](https://github.com/ignitionrobotics/ign-msgs/pull/189)
7. 🥳 Update ign-tools issue on README
  - [Pull request #184](https://github.com/ignitionrobotics/ign-msgs/pull/184)
## Contributors
_Louise Poubel_
_Nate Koenig_
_Steve Peters_
_TyHowellWork_
## Ignition Transport 10.2.0 (🏁 final Edifice release)
## Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-transport/blob/ign-transport10/Changelog.md)
1. Use exec instead of `popen` to run binary
  - [Pull request #300](https://github.com/ignitionrobotics/ign-transport/pull/300)
2. Focal CI: static checkers, doxygen linters, compiler warnings
  - [Pull request #298](https://github.com/ignitionrobotics/ign-transport/pull/298)
3. Add option to output messages in JSON format
  - [Pull request #288](https://github.com/ignitionrobotics/ign-transport/pull/288)
4. Remove no username error messages
  - [Pull request #286](https://github.com/ignitionrobotics/ign-transport/pull/286)
5. Documented the default value of `IGN_PARTITION`
  - [Pull request #281](https://github.com/ignitionrobotics/ign-transport/pull/281)
6. Remove static on `registrationCb` and `unregistrationCb`.
  - [Pull request #273](https://github.com/ignitionrobotics/ign-transport/pull/273)
7. Make zmq check for post 4.3.1 not to include 4.3.1
  - [Pull request #237](https://github.com/ignitionrobotics/ign-transport/pull/237)
8. NetUtils: simplify logic in `determineInterfaces`
  - [Pull request #257](https://github.com/ignitionrobotics/ign-transport/pull/257)
9. Fix Homebrew warning (backport from Fortress)
  - [Pull request #268](https://github.com/ignitionrobotics/ign-transport/pull/268)
## Contributors
_Addisu Z. Taddese_
_Alexander Graber-Tilton_
_Carlos Agüero_
_Hill Ma_
_Jose Luis Rivero_
_Louise Poubel_
_Martin Pecka_
_Nate Koenig_
_Steve Peters_
## Ignition Rendering 5.2.1 (🏁 final Edifice release)
## Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-rendering/blob/ign-rendering5/Changelog.md)
1. Silence CMake policy CMP0072
  - [Pull request #528](https://github.com/ignitionrobotics/ign-rendering/pull/528)
## Contributors
_Louise Poubel_
## Ignition Sensors 5.1.1 (🏁 final Edifice release)
## Changelog
[Full changelog](https://github.com/ignitionrobotics/ign-sensors/blob/ign-sensors5/Changelog.md)
1. Conform to ROS format for header field `frame_id` of sensor msgs
  - [Pull request #195](https://github.com/ignitionrobotics/ign-sensors/pull/195)
2. Fix compiler warnings (CMP0072 and copy elision)
  - [Pull request #188](https://github.com/ignitionrobotics/ign-sensors/pull/188)
## Contributors
_Louise Poubel_
