Logging and Observability Guide Review Part 4 | Cloud Robotics WG Meeting 2026-10-19
The next meeting of the CRWG will be at 2026-10-19T16:00:00Z→2026-10-19T17:00:00Z, where we will continue editing the first draft of the Logging and Observability guide. This will be very similar to the last meeting, except that the group hopes to finish the edit of the guide this meeting and send it to our prior guest speakers for review.
The meeting link for next meeting is here, and you can sign up to our calendar or our Google Group for meeting notifications or keep an eye on the Cloud Robotics Hub.
Hopefully we will see you there!
hi mike, hope the final pass went well. one thing i’d add under message publishing frequency, if it isn’t in there already: ros2 topic hz adds a subscriber and costs about 7% of a core on a 100 kb topic, so it doesn’t work as an always on fleet signal. what worked better for me was counting publishes inside each process and checking them against an expected min/max rate per topic, so the alert names the topic and the node. that fits carter’s point about alerts you can act on.
i built ros2_pulse while working on robot telemetry. it does this over the tracetools hooks and exports to prometheus and /diagnostics. linux only. GitHub - TanayK07/ros2_pulse: ros2 topic hz for every topic at once, without subscribing. Rates, gaps and node liveness, intra-process included, on stock ROS 2 binaries. · GitHub
happy to open an issue on the hub repo if that’s easier for the reviewers.
