LiDAR Selection Guide: Practical Comparison Between M360 and MID-360 After Purchasing 20+ Units
Our company specializes in robot integration solutions, and over the years, we have used quite a few LiDAR systems. Starting last year, we have extensively used Livox series LiDARs — mainly the MID-360 and M360. To date, we have accumulated over 20 purchases across different projects.
Here’s a practical comparison based on real-world project experience, not just spec sheets.
The First Step: Don’t Start with Parameters
Many people compare parameters first — range, power consumption, blind zone. Parameters matter, but we ask three questions first:
  1. Working environment? (Indoor / Outdoor / Semi-outdoor)
  2. Extreme conditions? (Rain, dust, high/low temperature)
  3. Budget?
These three questions can eliminate a significant number of options.
Practical Comparison: M360 vs MID-360
Range: 50m vs 70m
We tested with white walls (~90% reflectance) and a black sedan (~10% reflectance). Both LiDARs reliably detect over 50m on white walls. On the black sedan: M360 ~20-25m, MID-360 ~25-30m.
For warehouse navigation (3-5m shelf spacing), 50m is more than enough. For outdoor long-distance driving, 70m gives earlier obstacle detection.
Blind Zone: 5cm vs 10cm
This is significant in practice. We had a narrow passage project (1.2m width, 0.8m robot, 20cm clearance each side). With MID-360 (10cm blind zone), occasional wall touches occurred. After switching to M360 (5cm blind zone), wall touches basically disappeared.
For narrow space navigation (tunnels, shelf passages), 5cm blind zone is essential.
Vertical FOV: 70° vs 59°
M360: -10°~+60°. At 1.5m height, covers ground at 26cm and ceiling up to 2.6m.
MID-360: -7°~+52°. Ground at 18cm, ceiling at 1.9m.
For ceiling positioning (e.g., shelf navigation in supermarkets), M360’s advantage is crucial.
Power Consumption: 4.5W vs 6.5W
A 2W difference per unit. With 4 LiDARs (quadruped robot), that’s 8W — potentially 15-20 minutes of battery life difference.
Dual Echo (M360 only)
Practical uses:
  • Rainy day operation: Significantly improved point cloud quality in light rain
  • Glass detection: First echo = glass surface, second echo = object behind glass
IP67
Both are now IP67, but M360’s sealing has been market-validated longer.
IMU
Both have 6-axis IMUs. In practice, no significant accuracy difference. For high-precision pose estimation, use an external IMU (BMI088 or ICM42688).
Scenario-Based Selection Guide
Scenario Recommendation Key Reason
Indoor AGV/AMR MID-360 (budget) or M360 (narrow channels) 5cm blind zone for narrow spaces
Outdoor transport/inspection M360 IP67 + dual echo + wider temp range
Quadruped robots M360 (8S+ batteries or 3-4 units) Power supply + consumption
Mowing robots M360 5cm blind zone + IP67
Humanoid robots M360 (waist mount) 70° FOV better for waist mounting
Handheld scanning M360 5cm blind zone + dual echo for glass
Conclusion
Spec sheet numbers reflect ideal conditions. Real-world performance depends on installation angle, temperature, reflectivity, and motion speed. Always test a prototype in your actual environment before bulk procurement.
The few thousand yuan spent on a prototype is far cheaper than discovering issues after bulk purchase.
Based on actual project testing at SmartBotParts / TanTu ZhiXing. Parameters should be verified against official specifications.
Contact: sara.gao@smartbotparts.com
